Changed mehatronic sleeve now transmission won't shift
My Ride: m3 and 550i
I changed my transmission oil pans and the megatronix sleeves today and I made sure to align the shifter inside the pin on the megatronix unit when I put it back together. Now it's back together I refilled it was about 4 quarts of transmission fluid when I start the car and shifted into reverse or drive it automatically goes back into Park. Does anyone have any ideas what could be going wrong?
I just filled it till it was overflowing it said it was 40° on inpa. Do you know if there is any way that the parking cylinder could be in the wrong position I lined it up correctly but is it possible that I shifted is or something? Not really sure it was under some load I had to maneuver the handle to line it up with the PIN. But it looks just like it does in the picture. Thanks for the help I appreciate it
I check for codes today and there was no codes stored in the system but when I lowered the car it shifted through the years. And I was able to put it back up on the stands and add another quart and a half of fluid it seems to be going through the years now. Thank you for the help.
I definitely think it needs a little more fluid. I had trouble leveling the car I tried leveling it off of the transmission oil pan and it seemed if he's a little unlevel. I'm going to try releveling it this weekend with wooden blocks.
