Determining amp-hours for NCS after Batt change
Old 05-21-2019, 09:54 PM
Jnelson1182's Avatar
My Ride: BMW 525I
Default Determining amp-hours for NCS after Batt change
ok so I recently changed my batt and I went from a non AGM batter with a CCA@0' f=900 to a AGM batt with a CCA@0'f=850 and when I try using inpa/ista to do the registraition I get a communication error with the dme/dde, after learning that batt info was stored in the CAS2 module I decided to check mine and right now It Is set to 110ah-110 ampere-hours non AGM batt. The selections it offers me are 70ah__agm-70 ampere_hours(agm), 90ah_agm, 60ah_agm, 80ah_agm, heres the problem I have no idea how to figure out the ampere-hours on the battery however I do know that before I do too much driving I want to at least change this to see if it helps with any of the issues I am having so im hoping that someone knows how to do this or the best option I should use so I can load it into car asap.
Old 05-22-2019, 09:38 AM
Dappman's Avatar
My Ride: 2010 535i Xdrive M sport
Sometimes it says on the battery. If it doesn't I would just google the battery I'm sure you can find the spec easily.
Old 05-22-2019, 05:02 PM
My Ride: BMW 525I
that's what ithought but so far no luck, just a bunch of formulas to figure it out only I don't know the draw rate of the car so how can I figure out how many amp hours the batt can supply if I don't know how much is being pulled from it?
Old 05-23-2019, 11:15 AM
Dappman's Avatar
What's the exact battery that you put in it?
Old 05-23-2019, 12:48 PM
My Ride: BMW 525I
interstate agm cca850 an I took out a interstate non-agm cca900 batt
Old 05-23-2019, 02:36 PM
Dappman's Avatar
You're supposed to put the battery size/code too.
Just put 90 Ah AGM. That size battery should put out 90 Ah or more.
Old 05-23-2019, 06:07 PM
My Ride: BMW 525I
I tried that an now when I hook up ncs I get an error, its in german but im almost positive its a communication error too, im going to try uninstalling all the software an then reinstalling it to see if maybe somehow a setting got changed causing the issue cuz last time I used all 3 programs they worked 100% fine
dan2875
12-04-2019 07:50 PM
5soko
10-30-2013 05:44 PM
abarruda
02-12-2012 10:52 PM
Nocrapplease
02-12-2011 12:18 AM
JetBlack5OC
07-29-2007 08:17 AM
Quick Reply: Determining amp-hours for NCS after Batt change
