voltage
Old 04-16-2019, 03:34 AM
E54AHS's Avatar
My Ride: 525nsport
Default voltage
been told my alternator is OVER CHARGING guy took a plug off it saying its to do with smart charge? with wire on it was 15volts wire off its 14 volts he says alternator fkd but if its still charging how can it be fkd my freind says its possibility of a module instead of alternator anyone shed light on this good thing is no more warning lights appear on the dash
Old 04-17-2019, 07:29 PM
NoQuarter's Avatar
Sorry dude... not enough info here to make any helpful ideas.
You need error codes or something more helpful. 14 some volts when engine running is normal.
Old 04-17-2019, 11:06 PM
E54AHS's Avatar
My Ride: 525nsport
its the voltage regulator on back of alternator thats faulty just need to replace it cheers mate
Old 04-18-2019, 05:01 AM
FormerE30Owner's Avatar
From what you have described, one cannot definitely say that the voltage regulator is faulty. Nothing wrong with 15 volts charging the battery, depending on its state and type. And 14 volts resting is also normal. Sometimes "a little knowledge is a dangerous thing".
Old 04-19-2019, 05:18 AM
E54AHS's Avatar
My Ride: 525nsport
as soon as auto electrician disconnected the plug from regulator charging voltage was normal and not had any problems with the car thats 5days now so might keep fekn thing now 😎😁
Old 04-19-2019, 06:14 AM
GreaseMonkey535i's Avatar
My Ride: stock
its the voltage regulator. common issue I've replaced 2 in 3 years.
Old 04-19-2019, 06:29 AM
E54AHS's Avatar
My Ride: 525nsport
if its disconnectedand works ok why replace it old saying if its working leave it alone
Old 04-20-2019, 12:58 PM
E54AHS's Avatar
My Ride: 525nsport
well problem back again thought all was cured
Old 04-22-2019, 04:14 AM
E54AHS's Avatar
My Ride: 525nsport
what one did you get as i see a couple of different types
jehovden
11-30-2009 10:37 AM
jprovence
05-09-2009 03:16 PM
nigxdoof
13
01-15-2009 12:07 AM
nigxdoof
01-05-2009 10:58 PM
nigxdoof
01-11-2008 01:51 PM
Quick Reply: voltage
