E60 2005 Climate Control not receiving power
Old 03-07-2019, 06:14 PM
ACplease's Avatar
My Ride: BMW E60 2005
Unhappy E60 2005 Climate Control not receiving power
Hi all,
I had a faulty blower motor and resistor that I changed myself on my car. When the blower was faulty, I would receive no air (except sometimes the hot air from the engine) but the climate control lights and dials were illuminated and therefore receiving power. When I changed the old blower motor for a new one, my climate control no longer receives power. I've reinstalled several times to make sure I didn't miss a cable and I really don't see where I could've messed up. Anyone have any idea why it would stop receiving power? A side note... my CCC has most likely failed so I don't have access to iDrive. Unsure if that affects anything. The CCC unit still receives power as I can hear it spin. Any help to point me in the right direction would be appreciated!
Old 03-07-2019, 07:28 PM
Giubo's Avatar
My Ride: 520iA; 2004; M54; 170HP; A08; ABAT; 1CA; 2RA; 205; 235; 320; 423; 428; 430; 431; 438; 459; 465; 494; 508; 534; 540
A fuse check should be number one on your list.
Old 03-08-2019, 08:46 AM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
Check the 3 multi pin connectors on the rear of the IHKA panel to ensure they are properly seated, would be my guess.
refer to page 8.
https://www.bimmerfest.com/forums/at...8&d=1526135505
Old 03-18-2019, 02:17 PM
ACplease's Avatar
I'll check that out, thanks! I been pretty busy the past couple weeks but I finally have the time to work on it. Unfortunately, my battery died in the time the car sat in my driveway so I'm waiting on a new battery. Something I noticed while I was removing the battery was that there was some (what looked like) water pooled under the battery. Can't be good. It rained pretty hard for a few weeks, you guys think it was a leak from the trunk? Or could it be electrolyte from the battery?
Old 03-18-2019, 04:19 PM
Engine: M54 M10
Sounds like you may have plugged sunroof drains. Check the bottom of the spare tires well for water. You have electronics down there that may be taking a bath.
Old 03-19-2019, 12:52 PM
ACplease's Avatar
Thanks I'll check that area as well. I found my MPM module damaged a while ago and haven't used iDrive since. Perhaps this could be related...
Old 03-20-2019, 05:21 AM
Engine: M54 M10
A fried MPM may be the root cause...
Old 03-20-2019, 12:09 PM
ACplease's Avatar
Do you know if the MPM needs to be programmed after installing a new one?
Old 03-20-2019, 01:31 PM
Engine: M54 M10
Nope, plug and play, no programming required.
Old 03-22-2019, 02:46 PM
ACplease's Avatar
OK. So I checked some fuses today to see if I could find any problems and I found only one blown: Fuse #30 (air conditioning automatic). I also noticed I'm missing a couple fuses: #26 (air conditioning basic) and #35 (navigation). So hopefully that will fix my power delivery issue. I also checked the MPM again and indeed, it has a melted pin. I couldn't really identify and water damage in the trunk, but maybe one of you kind folk will see something I can't. I attached some pictures of the damage below. So my next steps will be to clear the sunroof drains, get a new MPM and fuse and hope she works!
looks like it has a little bend in the middle of it, could be a sign of damage
melted pin #3 from the left
don't see any water here
close up of where mpm was sitting
Jgiles54
10-13-2017 06:32 PM
DetailersDomain
Detailing Forum
10-13-2014 11:59 AM
healthservices
03-30-2011 04:09 PM
monsterj34
Bluetooth & Cell Phone Forum
16
07-22-2009 04:40 PM
woody
06-30-2006 12:11 PM
Quick Reply: E60 2005 Climate Control not receiving power
