How often you add coolant?
I have been adding just whatever amount it takes to go from the low mark to high mark on the reservoir float once or twice a year recently with no visible signs of any leaks,(suspect the coolant pipe and in the valley pan it evaporates I suppose), as it is just a small amount.
My Ride: E60 550i
Model Year: 08
This summer checked and added to bring it to high mark, now 4 months after I added 1 quart of coolant to bring to high mark again.
Was not sure if this is normal?
Use a UV light to look for coolant leaks. Coolant shows up like radioactive slime under UV light.
Harbor Freight has a UV flashlight for about $7 and it works great. That is how I found a leaking fitting that was basically ready to fall apart.
I have the N62 V8 and it was the Y connector for the upper head return lines. The fitting was make from something like Bakelite and was falling apart.
I replaced it with a brass T.
My Ride: E60 550i
Model Year: 08
No coolant warning message, just checked and added 1 quart after 4 months.
Around 1300 miles between additions.
Will get UV light-thanks for the tip, checked with phone light noticed small coolant amount on top front of the engine, see the 1st attached picture showing the direction/location.
Pictures 2, 3 and 4 are taken from website source with exposed area, arrows pointing where little coolant was noticed.
This could be damaged hose, cracked Y connector or loose clamp, will have to check closer after removing top engine covers.
Is removing the intake manifold a must in this situation?
How complicated it is to get access to this area?
My Ride: E60 550i
Model Year: 08
Ordered a complete hose with 2 clamps, based on pictures it should not be too complicated to replace it.
About UV flashlight, is this detecting coolant without having to add any dye or having to use glasses?
