G30 Discussion Anything and everything to do with the G30 5 Series. The G30 made it's debut in 2017
Headlight washer jets not workins
Old 09-17-2018, 10:04 AM
David Gould's Avatar
My Ride: 530d bmw 5 series 64 plate
Model Year: 64
Default Headlight washer jets not workins
Hi guys, just wondering if anyone has ever had a problem with the headlight washing jets for the 5 series ( 64 2017? )
mines had stopped working during winter. The fuses seem to be fine. Any suggestions ? i hear the main pump wirring when i press the stock
and the window jets are fine. but i dont hear anything from the other pump if there is one
Old 10-30-2018, 11:29 AM
tjkarch60's Avatar
My Ride: 545i w/sport
I have a similar problem on my 2005 E60. The headlight washer jets work the first time I use the windshield washer, but after that, the pump works, but the jets do not extend out.
I know the headlights have to be on for the headlight washer to work. If I turn off the ignition and use the windshield washer, the headlight washers again work for 1 cycle, then they turn into scared turtles.
Old 03-22-2019, 08:12 AM
Model Year: 64
Default (2014) 5 series 520 D 2L Headlight washer jets
Hi guys .
wince winter myHeadlight washers aint been working. i suspect that the motos have blow or the water hose has come off them.
I want to find out where the pump is to see if it is the pump that needs replaced.
Can anyone let me know where the pump is???
Also i have tried to take the fuses out that control it. Accoring to the fuse sheet i have taken out the right fuses for them BUT i highly doubt they are telling me the right ones to take out for some reason.
can somone help me out with this please.
thank you
tjkarch60
10-30-2018 11:40 AM
bmw535d M
05-05-2013 09:07 AM
klyeo
DIY: Do It Yourself
08-02-2009 09:34 AM
Phatisfy
6 Series Discussion
26
01-13-2009 08:25 PM
kompressorsf
12-22-2006 08:23 AM
Quick Reply: Headlight washer jets not workins
