Help!! replaced Trans solenoids and now doesnt crank
Old 09-16-2018, 08:34 AM
cnjames6's Avatar
My Ride: 525i
Default Help!! replaced Trans solenoids and now doesnt crank
I replaced the transmission solenoids on the valve body in my car, after putting everything back together, the car only "clicks" when pushing the start button. I used INPA to diagnose, and have the following faults,
DME/DDE CD99 D4
DME/DDE CD9E 54
DME/DDE CD9D 54
DME/DDE CDB0 54
the battery was reading at 12.5, any ideas will be appreciated!!!
PS 2006 525i
Old 09-16-2018, 11:21 AM
cmyachtie's Avatar
DME/DDE CD99 D4
DME/DDE CD9E 54
DME/DDE CD9D 54
DME/DDE CDB0 54
PS 2006 525i
voltage on battery alone of 12.5 doesn’t mean much, battery could still be discharged, suggest charge battery and double check any electrical connections you worked on first.
Old 09-17-2018, 05:15 PM
E60Japanese's Avatar
My Ride: E60 2006 sedan auto
It sounds like you never fitted the plastic slide for the gear select into its proper position when you refitted the valve body
You will need to remove the filter and you will be able to see it on the drivers side of the valve body
Old 09-18-2018, 10:23 AM
zoom750's Avatar
My Ride: 535i X-Drive
11:25 in this video...
Old 09-18-2018, 09:44 PM
Yes that's right
If that's not in the correct place you will not be selecting the correct gear so it won't start
The only other issue you may have is that you never fully engaged the big electrical plug after installing the valve body although I think i would check both to make sure
Ricapar
DIY: Do It Yourself
27
10-05-2019 01:24 PM
ianbmwe60
04-29-2015 12:49 PM
ianbmwe60
02-16-2015 08:32 AM
ianbmwe60
01-19-2015 05:30 AM
Anzafin
DIY: Do It Yourself
02-25-2013 10:07 PM
Quick Reply: Help!! replaced Trans solenoids and now doesnt crank
