Starts, Sputters, Dies within 5 secs
My Ride: 08 535i
My car died on me couple days ago, had to get it towed.
The car would start up fine, but would die right away. If i start it up and give it gas, the car would still die while giving it gas.
I am able to start it up, quickly put it in drive or reverse, and go for about 3-5 seconds before it shutoff on me and goes into neutral mode.
I have 1/2 tank of gas, its a 08 535i. No check engine light or codes thrown, i tried using the carly obd reader.
What do you mean "shut off"? After the engine died, you had no dash lights, no radio, etc?
OR everything worked correctly other than the engine stopped running?
Can you do the 5 sec test over and over?
OR once it stops running, it won't start again for a while?
My Ride: 08 535i
After it dies i can turn it on and drive for 5 sec, and keep repeating
My Ride: 08 535i
My Ride: 08 535i
