Thoughts On Coolant Brand
My Ride: 2005 BMW 545i
Engine: N62B44
What are everyone's thoughts on coolant in your vehicle? Is it bad form to use any 50/50 mixed coolant other than BMW house brand?
It's not only using the correct brand. The important part is making sure you use distilled water. These engines/radiators will work fine without the distilled but over time will damage it. Do not cheap out and go get 50/50 if you are planning to keep your car for a long time. You can also use the Pentofrost. 1 Gallon will be all you need.
Hi OP. Have you read the sticky link " New Here? Read This before you begin ? Take the time to review it, plenty of good info.
https://5series.net/forums/attachmen...-reformat-.pdf
Engine: N62B44
Originally Posted by dg-dave
I've only ever bought 50/50 mix.
I have been using predstone 50/50 for European cars and from what I can tell so far it is doing its job, I do plan on doing a flush soon so maybe ill look into a different brand then.
My Ride: 535i 6-speed
I have no idea if the specific brand matters. But for no more often than coolant is required, I just buy the BMW brand stuff and don't have to worry about it.
Howitzer
06-22-2010 02:45 PM
acribb
10-20-2009 09:19 AM
timsvulcan
DIY: Do It Yourself
10-19-2009 03:06 PM
