2009 535I Xdrive- Found this in my engine
Old 07-12-2018, 07:52 PM
olson109's Avatar
My Ride: 535I Xdrive
Model Year: 2009
Default 2009 535I Xdrive- Found this in my engine
I drive a 2009 535I Xdrive, I was doing a replacement of the valve cover and gasket on my car when I noticed this deep under the cams at the bottom of the timing chain. Can someone please tell me what this is and where it may have come from and or how to check or replace?
I know Im not giving much info but that's all I have. I did finish the install and car does run, but fear driving it. n54- this is where I was looking and saw the unknown gasket
pulled from under cam
pullfrom under cam
Old 07-12-2018, 08:02 PM
ripley's Avatar
My Ride: 2007 E60 530d
Engine: M57
Bit of shredded belt?
Old 07-12-2018, 11:44 PM
olson109's Avatar
Model Year: 2009
I have had no belt issues and this was inside the motor, saw it after I removed the valve gasket cover. I'm just hoping its not a gasket for something else.
Old 07-13-2018, 04:44 AM
Administrator
JayArras's Avatar
My Ride: 530xi
If you are not the original owner, perhaps it's left over from a previous sloppy repair job?
Old 07-13-2018, 05:42 AM
olson109's Avatar
Model Year: 2009
I am the 2nd owner of the car, I am just not sure what it is or how it would have even got sucked up in there, going to run a scan on the car this morning and see what code pop up.
Old 07-13-2018, 05:48 AM
audiophool's Avatar
My Ride: 535xi
Is it just a rubbery strip or does it have cord in it?
Old 07-18-2018, 10:00 AM
NoQuarter's Avatar
Looks like bits of the serpentine belt.
How long have you had this as the second owner and what miles are on it?
Old 07-18-2018, 12:36 PM
LessIsMore's Avatar
My Ride: 2009 535i Sport
Model Year: 2009
That looks, from pics too thick to be any kind of gasket, and has cords showing ... looks like a piece of belt to me.
Many others have the serpentine belt fail and the crank pulley, due to it's design, pulls/sucks pieces of the shredded belt behind it into the timing cover. Well documented. Seems like most plausible explanation. Prior owner had it repaired but the techs missed a piece.
Old 07-27-2018, 01:19 PM
fusionchicken's Avatar
My Ride: N54 535i, C6 Z06
Model Year: 08
I would take solace that the shredded belt never made your timing chain skip a tooth, that would have been a bad day
My 535i just shredded its belt so the wound is a bit fresh for me haha
cantinoz
05-15-2011 07:49 PM
cantinoz
04-07-2011 06:17 PM
cantinoz
04-03-2011 10:21 AM
cantinoz
01-24-2011 11:06 AM
cantinoz
01-10-2011 06:34 AM
Quick Reply: 2009 535I Xdrive- Found this in my engine
