serpentine belt squeal on cold start -06 530i n52 119k miles
Old 05-14-2018, 04:00 PM
ukr
ukr's Avatar
My Ride: 530i n52
Default serpentine belt squeal on cold start -06 530i n52 119k miles
Loud squeal noise from the serpentine belt on cold start up. Goes away after 20 seconds or when the engine warms up.
Engine has 119k miles, is it one of the pulleys or the belt slipping?
Old 05-14-2018, 05:51 PM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
What's your service history on serpentine belt, tensioner? If they haven't previously been changed renew all.... fcpeuro.com offers kits with all you will need.
Old 05-14-2018, 06:39 PM
ukr
ukr's Avatar
My Ride: 530i n52
Never serviced...going to order it.
Old 05-15-2018, 07:36 AM
NoQuarter's Avatar
You are aware how serious this is right? Don't put this off.
When the belt comes off, it can wrap around the crank pulley, get so tight is pushed through the front seal then destroys the engine.
Old 05-15-2018, 03:50 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
yep!! there are many threads out there regarding this.
Old 05-16-2018, 10:49 AM
ukr
ukr's Avatar
My Ride: 530i n52
I was doing trans oil, pan, and gasket change also. Might as well do the belt while the car is sitting. Going to check the alternator bearings, make sure it spins freely.
I was reading/watching some installation instructions and realized how important it is to 90 degree angle torque the belt tensioner bolt after its been torqued to 25nm.
Old 05-22-2018, 05:22 AM
ukr
ukr's Avatar
My Ride: 530i n52
Did the serpentine belt with pulleys..no more squeal.
The belt is riding on edge of the new tensioner pulley, unlike the old which was about 2mm inwards towards the engine. I didn't get chance to make a comparison between the old and the new tensioner to see if the pulley sits more flush with the tensioner.
gica69
10-19-2017 08:00 AM
ttboost
12-28-2015 08:28 AM
ck-e60
DIY: Do It Yourself
31
10-31-2015 04:34 AM
ray=out
05-24-2011 02:47 PM
Raheel312
DIY: Do It Yourself
07-01-2009 05:03 AM
Quick Reply: serpentine belt squeal on cold start -06 530i n52 119k miles
