Bmw msport 525i high pressure in radiator hose. ??
Old 04-21-2018, 10:48 AM
Hsv666's Avatar
My Ride: Bmw msport 525i
Default Bmw msport 525i high pressure in radiator hose. ??
Trying to find a bleed screw mine does not have electric water pump it has Mechanical and can't find bleed screw anywhere how do I get around this and if water bleed process is done incorrectly will it cause excess pressure in the system or am I looking at maybe a head gasket
Old 04-21-2018, 11:13 AM
jtbgonesailing's Avatar
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
You probably have the m54 engine, there is no bleed screw for the cooling system. Start the engine, set the climate control to maximum heat setting and fan on lowest setting. Run the engine 10 minutes or so with the expansion tank cap off. You should see a stream of fluid entering the expansion tank in the top front. Shut engine down, let system cool down, top off coolant, reinstall cap, done.
Good luck.
LJTX545I
01-05-2015 06:37 AM
Rizbel
03-05-2013 05:18 PM
far1977
08-05-2009 02:02 PM
tex_phil
06-16-2009 11:28 PM
Allen
06-11-2009 12:24 PM
Quick Reply: Bmw msport 525i high pressure in radiator hose. ??
