2006 e61 oil level not in I-drive
My Ride: 530xi
Engine: M54
hey guys. So I previously had a 2008 535xi so I know how to and the location of the oil level. So I sold that car two years ago and a few days ago picked up a 530xi touring. When I go into the I drive it only has service info and no tab for the oil level. How do I go about checking the oil on this car and is there a way to get it to show up there? Has anyone else had this issue? I saw one or two threads of people having the same issue with no conclusion. Thanks in advance!
This is a new one for me.
Anyone have any ideas on what makes the oil level indicator go missing from the iDrive screen?
Can you make it come up on the instrument cluster at all?
My Ride: 530xi
Engine: M54
What’s the process of making it appear on the cluster? I never had to do it with my other car and didn’t see it in the manual. I held the top button for obc as I saw someone in a thread say but it just showed the two faults for my led lic plate lights and nothing else.
I have a pre-LCI 07 530iT (nee xiT). I tried to get the oil level to show in the gauge cluster with all the coding mishegaas but finally gave up. I think it's just a LCI option, as is showing actual tire pressure values.
To navigate to the oil level I do this:
Info > Info Sources > Service Info > Service Requirements > Oil Level
Are you saying there isn't oil level if you drill down into Service Requirements? This is the level at which you can see the time to service the various things like plugs, microfilters, brake pads, etc.
I'm sure the menu option could go away somehow but I wonder if you've got it in your head where it should be from memory and you're a page off. To be clear, not trying be a dick - I've just been there where I'm certain something is here only to find out it's there.
Cheers,
Andy
07 530 EX-XIT
Cheers,
Andy
07 530 EX-XIT
My Ride: 530xi
Engine: M54
It shows the time in which it needs service there but not the actual level in the car. I’m sitting in it now and checked and double checked. It’s crazy, if it were to go low or even if I were to do an oil change I would have no clue what to fill it to.
If you're talking about the fill level after a filter/fluid service, there's either forums that give the spec or a few electronic BMW service tools like ISTA+ and the older TIS that will give the fill level. The N52B30 engine (and I suspect the later N54) take 6.5qt with filter change.
As frustrating as it is to not have a dipstick, it is another leak point for both oil and crankcase pressure, which has to be accounted for in the emissions report to the various governing bodies. More cynically, BMW is pushing for customers to not do their own service (hence barely any specs in owner's manuals anymore - wheel torques, fluid capacities, etc) - a dumbing down of the owner, if you will. I'm an engineer at an engine company and many people I work with can't be bothered to do basic work. It's the way we're trending.
As a sidebar, I bought a BMW S1000R motorcycle and they publish the bejesus out of the specs - different market, obviously, but one that is well known to be very self-sufficient and one that demands the info. There are many other capable bikes out there and people will change brands for lesser things.
Cheers,
Andy
07 530 ex-xiT 6MT
My Ride: 05 BMW 525
Engine: M54B25
I have an 05 525i so Pre LCI. The oil level option wasn't available in the iDrive menu but I found a way to code it However, it shows a no measurement error so I'm guessing either more coding has to be done or just update to a new sensor. Btw I know for a fact the sensor that is already in the car is working fine because I got a low oil level warning the other day. (Oil pan gasket leaks)
My Ride: 05 BMW 525
Engine: M54B25
iDrive menu added via coding
