Does BMW use real wood in the trims?
Old 12-18-2017, 02:09 PM
edyu's Avatar
My Ride: 550i E60 Alpine White
Question Does BMW use real wood in the trims?
I know that some M Individual has real wood trims but how about the regular E60s? For example, I have "dark poplar" and it looks like wood but feels like plastic so it's hard for me to tell. Does anyone know whether BMW (considering it's a premium brand) use real wood in the wood-sounding trim names? I believe diamond black is plastic but piano black is real wood?
Old 12-21-2017, 02:08 AM
richie281vn's Avatar
My Ride: 2006 525i
Model Year: 206
its plastic except for the individual trim. my 2cents
Old 12-21-2017, 03:06 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
it is NOT plastic. yes, they use real wood veneer.
Old 12-21-2017, 04:05 AM
Allen's Avatar
My Ride: 535i 6-speed
this...albeit, a very thin layer, the part you see and touch is real wood.
Old 12-21-2017, 04:06 AM
Allen's Avatar
what does that even mean...??
Old 12-21-2017, 04:34 AM
NoQuarter's Avatar
right... real wood layer covered in a poly of some sort.
Any scratches can be buffed out/polished
ughhh - our X5 has nearly every wood trim piece cracked. It seems it is just the poly layer and makes me wonder if it can be re-coated to blend the cracks back together.
Old 12-21-2017, 05:45 AM
FormerE30Owner's Avatar
Try using a clear nail polish or acetone. That might work.
Old 12-21-2017, 01:05 PM
edyu's Avatar
While researching what I can do with trim, I came upon a CF refinisher vendor for audi ocarbon.com and as he was refinishing some trims for an E60, the pictures clearly shows some wood after he stripped off the resin to wrap it in carbon fiber. However, considering it's an M5, it still doesn't definitively do show normal E60 having real wood.
It does look like Kyle might be right in that it is real wood but think veneer.
Old 12-22-2017, 02:59 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
Trust me, they are all real wood veneer. BMW used a lot of the same interior trim components across all lines including the M5.
Old 12-22-2017, 02:04 PM
edyu's Avatar
Nod. I trust you. I like the "diamond black" but I believe that's really just shiny black plastic. The other trims (other than aluminum) are real wood veneer.
Quick Reply: Does BMW use real wood in the trims?
