Tires & Wheels Ask all of your Tire & Wheel questions here!
e60 oversized tires
Old 10-22-2017, 06:45 AM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Default e60 oversized tires
When the 2010 528i was launched it had 225 50R 17 sized tires.
Can the body handle 235 50R 17 tires without wheel well modifications?
Will putting on wider tires throw new error codes?
Old 10-22-2017, 07:47 AM
Administrator
JayArras's Avatar
My Ride: 530xi
You shouldn't have an issue since you don't have an AWD car. People go to 20" rims on our cars, so running 17's won't be a problem.
Old 10-27-2017, 12:23 AM
JuniorB's Avatar
That is a taller tire, if you want to go wider, go with a 40/45, a 50 series is taller. Honestly, dump the 17's and run 255/40r18. They will fill the well nicely without going to low. If you want to go wider a 245/40r17 would be about your exact size but wider.
Old 10-10-2018, 11:29 AM
My Ride: 528i
Engine: N52k
I have a 2010 528i e60.
I would like to go with a wider 245 tire you suggested. I worry that it will hit the inside of the quarter panel.
Do we know that a ton of guys have put 245's on their stock 17 inch wheels?
Old 10-10-2018, 01:50 PM
Administrator
JayArras's Avatar
My Ride: 530xi
We don't know that, but you can ask.
Old 10-11-2018, 07:12 AM
utah's Avatar
My Ride: 2012 5 Series Manual
Would like to know as well.
Old 10-11-2018, 11:31 AM
FormerE30Owner's Avatar
The manual for my 2005 545 indicates that 245/45-17 tires are acceptable.
Old 10-21-2018, 04:54 AM
ama66843's Avatar
My Ride: 535i xDrive Touring w/Logic 7
Yes, I've heard the pre-LCI cars had 245/45-17" as an acceptable uprated size. I'm looking to make the same move on my 2010 e61, but such specs are no longer printed on the driver's door panel.
The rotating radius is extremely close between the two sizes, the only issue is where the 7.5" rim is fine with the 245 width tire (so a stretch/width issue).
any xDrive/e61 people?
Old 10-21-2018, 07:16 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Note that it's not the rolling circumference comparison between two separate sets of tires that matters, it's the rolling circumference among the four tires of the same set that matters.
Old 10-21-2018, 07:26 AM
ama66843's Avatar
Of course, but if you want to avoid speedo/electronics issues, your replacements better be damn near the stock rolling diameter.
