06 530xiT No crank no start after locksmith
So, was working on converting the tailgate from Auto to manual and ended up locking my only key in the cargo area...
Had a locksmith come out, they unlocked the car by pulling on the door handle from the inside. Alarm went off and turned off before I could get the key. Unlocked it, thought nothing of it, and went back to work.
Fast forward to this morning, car tried to crank, but didn't start. Every time after that, it's been a no crank no start. Everything else still works. Took the battery to AutoZone, they said it was good and showing a 75% charge. I took a voltmeter to it and it was showing 12.65v.
Reinstalled the battery and now I'm getting the 4x4 and DSC malfunction on top of it refusing to start...
I have a starter on the way, but besides that, does anyone have an idea as to what else it could be? Does the immobilizer somehow need to be reset?
Thanks for any help.
Skipped the gym this morning to run my one free iCarly report:
Fault Report - Carly for BMW - Version: 25.30 LV
ID1: b59c6e34-fa09-4a85-a3f4-018b099e923b-855 ID2: 83f206b4-cc6a-4a13-8f0b-6effc7745ae0-e30-6bfe4021112e0717
INFO: 020DE4D3C3BEAA947F71634B3E2DE
Base: E60 E61
Build-Year: 2006
Faults: 5
ECUs: 35
Filter: just found
Model: 5 Touring (E61) Automatic engine recognition (MotorID=91, Parameter=28)
Battery: 11.0V
ADDITIONAL OBD: OFF
Normal communication
Normal connection
normal
B 1
Date: 2017-10-03 05:38:47
OBDII
Version: 26
Device: >Google< >marlin< >Pixel XL<
Motor Control:
Engine / Motor
ECU OK, no Fault Code
ABS / DSC / Brake:
Active Roll Stabilization / Rollstabilisierung
ECU not present/no response from ECU
Dynamische Stabilitaets Kontrolle / DSC
Steering angle sensor
Code: 005EBA
Airbag:
Advanced Crash and Safety Management (ACSM)
Driver Headrest
Code: 0093F9
Satellite front left door / Tuer vorne links
Satellite front right door / Tuer vorne rechts
Satellite B-pillar left / B-Saeule links
Satellite B-pillar right / B-Saeule rechts
Satellite center / Mitte
Airbag B-pillar left/ B-Saeule links
Airbag B-pillar right/ B-Saeule rechts
Transmission Control:
Transmission / Getriebe GS 19
Transmission / Getriebesteuerung
Gear switch / Gangschalter
Instrument cluster:
Instrument cluster / Kombiinstrument
Central info display / Zentrales Display
Head-Up Display
Light/Rain Control:
Light / Licht
Rain/light sensor / Regen-Lichtsensor RLS
Light / Licht
High-beam / Fernlichtassistent
Heating / AC:
Air conditioning / Klimaanlage
Short circuit to positive or open circuit (AUC)
Code: 009C54
Additional heater / Zusatzheizung
Immobilizer System:
CAS
Park distance control:
Park Distance Control / PDC
Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung
Sunroof / Roof:
Sunroof / Schiebedach
Audio/Navi/Communication:
Multimedia-Changer / Wechsler
Speech recognition / Spracherkennungs-system
Phone / Telefon
GPS module fault
Code: 00A36B
Hifi Amplifier / Verstaerker
Tuner Antenna / Antenne
Hybrid Radio USA
Digital Satellite-Tuner USA
Headphones / Kopfhoerer Schnittstelle
Navigation
CD-Changer / Wechsler
Audio-System
Video
DAB
Seats:
Backrest width / Lehnenbreiteverstellung
Seats / Sitze
Seats / Sitze
Systems:
Gateway
Steering column switch / Lenkstockschalter
Fuel pump / Kraftstoffpumpe
Tire pressure control / Reifendruck Kontrolle
Passive Go System
Power Module
Night Vision
Flexible Bus-Interface / Schnittstelle
Car Communication Computer CCC
Message failure
Code: 00E18F
MASK
Center-Konsole
Night Vision Camera
Car Communication
Anti-theft alarm system:
Interior protection / Innenraumschutz
Theft alarm / Diebstahl Warnanlage
Chassis:
Air suspension / Luftfederung
Electronic damper / Elektronische Daempfer
Central Control / Zentrale Bedieneinheit
Body:
Automatisches Front Steering
Trailer / Anhaenger
Car Body Module
Tailgate / Hecktuer
Other:
With CAS showing fine, I'm going to assume it is indeed the starter. I've checked any fuse that deals with engine/ignition/fuel and they all appear fine. I'll most likely pick up a battery charger as well on my way home from work just to keep the battery charged while I wait.
If anyone has any other guesses as to what the issue could possibly be, I'm all ears.
Base: E60 E61
Build-Year: 2006
Faults: 5
ECUs: 35
Filter: just found
Battery: 11.0V
ADDITIONAL OBD: OFF
Normal connection
normal
B 1
OBDII
Version: 26
Motor Control:
Engine / Motor
ABS / DSC / Brake:
Code: 005EBA
Airbag:
Driver Headrest
Code: 0093F9
Instrument cluster:
Head-Up Display
Light/Rain Control:
Light / Licht
Light / Licht
Heating / AC:
Code: 009C54
Immobilizer System:
CAS
Cruise Control:
Sunroof / Roof:
Phone / Telefon
GPS module fault
Code: 00A36B
Hybrid Radio USA
Navigation
Audio-System
Video
DAB
Seats:
Seats / Sitze
Seats / Sitze
Systems:
Gateway
Passive Go System
Power Module
Night Vision
Message failure
Code: 00E18F
MASK
Center-Konsole
Night Vision Camera
Car Communication
Chassis:
Body:
Trailer / Anhaenger
Car Body Module
Tailgate / Hecktuer
Other:
Won't hurt to bang on the starter in the meantime, I suppose.
I had my starter go out while I was out of country and my wife was driving it. I think it just went out without warning but then again my wife tells me nothing until it just doesn't work. Since then I have learned how to rebuild starters which is very easy and takes about 30 mins. I would suggest that if the starter is your issue. The kit costs around $30 and it is worth it. My first time I had no idea what I was doing. I just payed attention on how I took it apart and replaced the parts in the kit. It saved me $300 and every since then I rebuild instead of buying reman or new
I was lucky enough to find one off of Amazon for $50 and it should be here tomorrow.
Update.
Took the battery to Autozone. They said it was good. Took it home, tested it with my voltmeter and it was showing around 12.65.
Re-aligned the CAS on INPA and it showed good. Let the battery trickle charge overnight. Still nothing.
So hopefully it is indeed the starter as I'm changing it out today!
For the record, hitting a modern starter with a hammer is a bad idea. Back in the 'old days' field coils were used for the stationary magnetic field. New ones use ferrite magnets that will break if you belt the starter with a hammer. JSYK.
As far as I know to even reach the starter in the N52, I have to take the intake manifold off.
If I'm gonna be doing that much work, I'll just replace the damn thing.
