Right License Plate Light Not Working
I got an alert last week that the right license plate light was out. The light bulb had simply burned out. I replaced the light bulb and the alert went away and all was well. Then a day later I got the alert again.
The light was out.
I did a continuity check on the light socket and the bulb and it has continuity. I removed the socket and there is no voltage at the connector.
The left license plate bulb is working just fine.
Is there a fuse or something that could be open causing this or why is there no voltage coming out of the socket?
The light was out.
My Ride: E60 M Sport 530i
As others have said, it is the wiring in trunk lid hinge. Read the thread 'very unusual boot opening problem ' and read my posts there and you will find the info you need to fix..
Ralph Avery (03-19-2021)
