Water on the passenger side floor board
Old 06-24-2017, 05:56 PM
Chucks2010's Avatar
My Ride: 2010 BMW 528i
Default Water on the passenger side floor board
Hi I'm sure this has been asked many times. I tried to do some research and found several different things it could be similar to. Here's what I have going on - 2010 528i. Water on front passenger side . Car was not driven for a week . Lots of rain with TS Cindy coming to town . I got home from vacation and noticed lots of water there. When i opened the door water came out of bottom of door too. Where is the most likely spot this is coming from ? Some say the sunroof drain , some say drain under hood.then there's the vapor barrier behind the door panel . I really don't want to go thru all of them to find the problem . Most likely possibility? Thanks in advance .
Old 06-25-2017, 04:12 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
sunroof drain, might need to remove the A pillar trim to make sure nothing is disconnected too.
Old 06-25-2017, 05:42 AM
Chucks2010's Avatar
So the sunroof drain might also let water in the door itself ?
Old 06-25-2017, 09:01 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
are you still noticing water draining from the door when you open it? is the carpet on the RF of the car damp?
Old 06-25-2017, 11:13 AM
Chucks2010's Avatar
Yes water drained from the bottom of the door when I opened it. Floor board had lots of water in it
