Leftover parts from CIC Retrofit (CCC, Display, TCU, MULF2, etc.)
My Ride: 535
Finished a CIC + Combox retrofit on my car, and now that I'm confident that everything is working properly, it's time to sell off everything. This is from an LCI (MY2008) 535xi. Everything was working as expected when removed from the car. Here's all the parts I have
CCC Headunit. LCI version with the the US-style 8-buttons (1-6 + AM/FM/Mode). Asking $250
CCC Display. Asking $100
CCC iDrive Controller, knob, and menu button. This is the LCI version, so there's no haptic feedback. Knob is the non-M style which doesn't look as cool. Asking $30
LCI CCC Trim - this is needed if you want to use an LCI CCC in a pre-LCI model. Asking $20
MULF2 High + USB Hub. With this you can get USB and Aux support, and the module also supports bluetooth. The USB-hub would theoretically allow a second USB port to be installed somewhere, but my car only used one of the two ports. I'm not sure why it came with the hub at all, but it did. Asking $75
TCU1.5 -- BMW Assist no longer works because of the 2G sunset, but the bluetooth functionality should still work fine. Asking $50
IBOC (HD Radio) Module w/ Antenna multiplexer - This module will allow you to get HD Radio on a CCC-based system. The multiplexer allows you to keep the real-time-traffic-information functional. Asking $100
All modules were flashed to the latest software in late 2010 (which should still be current today)
If you want to buy everything together, I'll let it go for $400 + shipping.
Please PM me if you're interested in anything or have any questions
