E60 / E90 CIC Conversion kit
Old 05-29-2017, 08:59 AM
ericgla's Avatar
My Ride: 2008 E61
Default E60 / E61 CIC Conversion kit
I'm selling my CIC that has served me well in my '08 E61.
The kit includes
CIC head unit pulled from a 2010 E60 (6512-9222876-01)
CIC display pulled from the same 2010 E60 (6582-9211696)
Display cable
CIC emulator (to enable nav, etc)
Camera emulator (for backup camera)
GPS antenna (not shown)
$650 + shipping
This kit does NOT include the LCI climate controls and CIC console cover, but can point you to a salvage yard that has them in stock.
03-08 E60/E61
There are a few additional items that you will need to complete the conversion. You will need
LCI console cover plate for climate controls and CIC
The IDrive controller upgrade is optional, and is not required for the CIC to function. I used the CIC with my old controller in my '08 E61. If memory serves me correctly there is a coding option to specify the controller type.
09-10 E60/E61
This is everything that you need. Your vehicle already has the updated IDrive controller.
All this is well documented in the forums, but hopefully this will help anyone considering the conversion.
Attached Thumbnails E60 / E90 CIC Conversion kit-img_20170529_104551.jpg   E60 / E90 CIC Conversion kit-img_20170529_104608.jpg   E60 / E90 CIC Conversion kit-img_20170529_104654.jpg   E60 / E90 CIC Conversion kit-img_20170529_104717.jpg
Old 05-29-2017, 03:31 PM
wooboodoo's Avatar
My Ride: is black
Model Year: 535
CIC from e90 will not work in E60/61 or other direction, different gateway.
Old 05-29-2017, 04:20 PM
ericgla's Avatar
My Ride: 2008 E61
Oops, my bad! Updated the post.
Old 05-29-2017, 06:57 PM
Tunerbuilder's Avatar
My Ride: 2005 545i SMG with many, many options. More than my '17 C300 sadly....
are the LCI climate controls required? I quite like the pre-lci climate controls.
Old 05-30-2017, 11:06 AM
ericgla's Avatar
My Ride: 2008 E61
I'm not 100% sure. My car had M-ASK, so I needed a new faceplate to cover the taller head unit, and the non LCI climate controls don't line up with the e60 faceplate, which has the bezel for the climate controls built in.
If you are upgrading from CCC, you may not need to upgrade the climate control panel. Since this upgrade is very well documented, I would read up on the forums to be sure.
Old 05-30-2017, 08:37 PM
radumalica's Avatar
My Ride: 530i 2008 LCI
Depends if the car is LCI or not, regardless of CCC or M-ASK. LCI cars have a different panel for A/C controls and the faceplate is different. This is for the upper part of the dash. For the lower part, again depends if your ashtray is pop-out model between the buttons (LCI cars) or in the lower part (pre-LCI). This will tell you what type of trim do you need and if you need to change ashtray location. As CIC and CCC are full height, they need a trim without the in-dash pocket like M-ASK has.
Old 06-11-2017, 09:36 PM
drift3r's Avatar
My Ride: e61 LCI
interested. will PM
Old 06-13-2017, 09:07 AM
ericgla's Avatar
My Ride: 2008 E61
The kit has been sold.
