Need help With idrive controller BMW e60
Old 05-04-2017, 11:17 PM
Codrut Popescu's Avatar
My Ride: BMW e60 525d
Default Need help With idrive controller BMW e60
Hello. Please help me with my problem. After i've updated MOST module from 9185627 to 9185636 using winkfp..all went well, i passed to airbag module SIM...all well but after completing The update my idrive controller wont work??? I cant understand why. Please help me with some answers. Thanks
Old 05-10-2017, 11:42 AM
NoQuarter's Avatar
Does the knob just spin freely with no force?
Old 05-20-2017, 07:30 AM
Yes...doesn't do enything...sorry that y didnt reply
Old 05-22-2017, 06:42 AM
NoQuarter's Avatar
Something that may be related....
Years ago I upgraded my old iDrive controller (the one with only the menu button) to the newer design with all buttons for Nav, Radio, etc.
There was a setting in the module I needed to change - something about hi vs low. Prior to the change, the knob would spin freely and do nothing in the display. After the coding change, the knob had the proper force feedback and worked correctly.
Try doing some search for iDrive controller retrofit and see if anything helps.
Old 05-23-2017, 06:52 AM
i made The research..i hale tryed With 'low_with_slopes' Thing. Doesnt do enything. I've cheked The wire...allora Good. Thank You. Sorry for my bad english
Old 05-23-2017, 07:08 AM
NoQuarter's Avatar
No apology needed. Your English is working well enough!
Have you tried this site for more coding info? bmwcoding.com
Old 05-29-2017, 10:51 PM
2real4u's Avatar
Program MOST_GW with 9185627. 9185636 is for ZBE2 (newer 7-button controller).
Old 05-30-2017, 12:05 AM
Hello!! How can i do That? When i chose 9185627...winkfp allways reveals that The update Will be maked with 9185636. And in my UIF in inpa...i allways have 9185636. First IT was 9185627. Thank You...any help needed. How can i return to The older version...9185627
Old 05-30-2017, 12:07 AM
i will check it. Thank you
Old 06-06-2017, 11:11 AM
radumalica's Avatar
My Ride: 530i 2008 LCI
Do it in expert mode not comfort There are a pletora of howto's here and bmwcoding about how to flash the CIC / MOST /CCC with specific PABD in expert mode . Comfort mode will just give you the new available ZB . Most probably you need to downgrade SPDATEN to the version which has your original ZB number. Make sure only MOSTGW is flashed via DCAN (i.e, CAN address 0x62) otherwise you will brick your thing. (63 and A0 need ICOM on MOST ASYNC)
