E60 m5 engine management light half power help plz
Old 02-18-2017, 06:46 PM
Jake Sargood's Avatar
My Ride: bmw e60 m5
Cool E60 m5 engine management light half power help plz
Hi I'm Jake got a e60 m5 and when I'm driving in msport and giving it some my engine management light comes on and says half power if I turn the car off straight away and restart the light is still on but if I let it cool down for 5 mins the light is gone and car is fine again untill I drive it msport and when light is on engine runs a little bit hotter but when I'm not in msport the light does not come on
Old 02-19-2017, 02:21 PM
seanjordan20's Avatar
You will have to get the code it is throwing before someone can help. It could be alot of things that cause your issue....
Old 02-27-2017, 05:44 PM
jcolley's Avatar
My Ride: 2006 M5
4500 RPM redline, DSC Malfunction, ABS Malfunction, Start-off Assistance Malfunction, Reduced power errors? If so most likely a throttle actuator. Need to have codes read to be certain.
Old 05-04-2017, 05:18 PM
Bcas's Avatar
My Ride: 06 E60 M5 S85 5.0L
Default There are 2 actuators, fyi...
I replaced both actuators and AC compressor clutch and belt drive system. Also are you using quality oil? I use Liquid Moly 10w 60.......I'm also going rebuild my Vanos units ,the seals and the bearings need replacing.
Old 05-04-2017, 05:39 PM
jcolley's Avatar
My Ride: 2006 M5
What bearings and seals? The S85 VANOS has no serviceable components other than the solenoids.
Old 05-05-2017, 12:52 PM
Bcas's Avatar
Inside the dual vanos units? I was told that the seals in the units wear out over time, and bearings in the unit.. dont know the technical terms, but have seen the parts, and process.... but thanks bud
