BMS OCC servicing feedback
Hello all, I just got the BMS OCC and see that I am to locate it hanging off the drivers side strut bar. I certainly have the space to do so but am concerned about how easy it will be to unscrew the bottom portion so that I can drain the oil. Looking for others experiences on this.
Thanks,
Eric
Thanks,
Eric
My Ride: 535i M Sport
If you have DCI's it's not hard at all as long as you don't over tighten the canister. Besides, it doesn't need to be emptied very often. I empty mine once a year and usually only get a few tablespoons of oil, but some cars blow more oil than others. In my case, I could probably go 2-3 years without emptying it.
Ah, well, as you can guess from my question, I do not have DCIs, Still running the stock airbox system.
Eric
Eric
My Ride: E60 2010 535i /FBO
Get rid off the stock box... the sound is amazing running dci
Take care of em, clean em, hit it with some oil [red] and bam
Yes Heat soak can be an issue if your not running an intercooler
