Airbag SGM fault 93F9 - how to fix it?
Old 02-25-2013, 09:40 AM
zinchuk77's Avatar
Default Airbag SGM fault 93F9 - how to fix it?
I have this problem with my 2005 545i. Air bag light came on and last year dealer replaced my seat sensor under recall and the light went away but it came back 6 months ago. I took the car back and they said this error is not related to the recall they performed when they replaced the seat mat. The dealer ran a test plan and said that I need a new airbag module, but i dont know if i believe them I tried to clear by INPA but can not clear it. Code reads :
93F9 Spannnung Energiereserve U60 n.i.0
Does this mean my passenger airbag will not deploy? Can you guys help me please?
Old 02-25-2013, 11:36 AM
AchtungE60's Avatar
My Ride: E60 530i
hey bud I received your PM.
The error is in SGM/SIM. Are you clearing the IM, EM,and HM? (info mem, error mem, history mem)?
Just read the UIF EM and then do a clear and see what happens first.
Old 02-26-2013, 07:40 AM
zinchuk77's Avatar
hi, i tried to clear it in all IM, EM and HM but it does not go away. it can not be cleared. what do you think guys?
Old 02-26-2013, 05:48 PM
bymer's Avatar
Hey I have the same issue man, 93F9.
Only way to clear the code is to update/reflash the SGM module using progman or WINKFP if you are comfortable using it. Only then it will clear itself. But it comes back in a month or so.
After searching for weeks, not a lot of info could be found on this issue, I think that the module needs to be replaced or there are some electrical issues that make this happen. (I also changed my battery thinking it was the issue, did not help.) If anyone can chime in on this, would be great!
Old 02-26-2013, 06:37 PM
zinchuk77's Avatar
thanks man. can you share info on how you did it with WINKFP, i would like to try to clear it also. is there a write up or do you have any screenshots?
Old 02-26-2013, 07:42 PM
stel_i79's Avatar
My Ride: 530i N52
Engine: n52
Thats what my dealer told me i have to change the SGM module. ~$1500
I ask them if for this price is included also a new softwear version for my car ( i have like v23 or something)
And they told me that they will only update the sgm and the car softwear will be extra ~4-500$
I guess i have to suck it up and get over with this f#%^g passanger airbag mulfunction
Good luck to all of you with this issue
Old 02-26-2013, 09:23 PM
dawid_w's Avatar
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Hi,
Don’t waste your time andmoney on the airbag module. I had the same problem with my 545i. I was able tofix it by replacing battery positive cable (SBK).
This cable has a module thatreports to airbag system and this cable is known to have issues.
I replaced the cable with theupdated version that was installed on 550i. You will need also to modify thesmall harness connecting to the cable
You will need followingparts:
61126989780
http://realoem.com/bmw/showparts.do?model=NB53&mospid=48806&btnr=61_1760& hg=61&fg=10
61129193975
http://www.realoem.com/bmw/showparts...61&fg=10&hl=14
GL
bimmer7410 (08-19-2019)
Old 02-27-2013, 10:38 AM
zinchuk77's Avatar
Originally Posted by dawid_w
Hi,
61126989780
61129193975
RealOEM.com BMW E60 550i Repair cable, airbag
GL
ok, thanks for your help. is this cable hard to install, where does the other end connect, is the end of it somewhere in the trunk or does it go all the way in the car under the floor?
Old 02-27-2013, 11:24 AM
balbs's Avatar
My Ride: BMW
Hi,
61126989780
61129193975
GL
Hmmmm....You also got the 93F9 code but replacing the positive cable fixed it? I thought the code 96CA is the code for high resistance which is on the positive cable.
Old 02-27-2013, 02:46 PM
mickeyboy500's Avatar
My Ride: 2005 E60 535d, Carbon Black, Beige Leather, 20" Lenso Alloys, Quad Powerflow Stainless Exhaust, Remapped
I have the sane error on my 2005 535d and have been trying to fix for some time now with replacement of the SGM-SIM (Safety & Gateway Module) being a last resort given what a replacement costs. Have replaced and registered a new battery but to no avail.
Going to disconnect the battery and then check all the connectors on the SGM itself to ensure that it isn't a poor connection next, but I am fast coming to the conclusion that a replacement SGM will be the only way to resolve this.
So keeping an eye on this thread with some interest.
Quick Reply: Airbag SGM fault 93F9 - how to fix it?
