the way E60 was meant to be
Old 11-09-2012, 07:52 AM
dbond's Avatar
Default the way E60 was meant to be
- "At a touch of a button it becomes one of the very best ..." - Clarkson
Tactile, responsive are probably not the words that come to mind when you are behind the steering wheel of a big 4 door sendan such as E60. May I present you THE button to change your perception of E60. The button that transforms 5' to a vehicle BMW engineers meant to be. Before bean counters and MBAs got their hands on the blueprints.
It's called FDC (Fahr Dynamic Control).
Here is what BMW have to say about FDC:
"Dynamic Driving Control (FDC) can be selected with the SPORT button in either automatic mode or manual mode. FDC is always deactivated when the engine is started.
When Dynamic Driving Control (FDC) is activated with the SPORT button, shift times for gear changes are reduced by the SMG control unit. In addition, in automatic mode the SMG only shifts into the next gear up at higher engine speeds. The DME unit adjusts the accelerator-pedal values. The engine responds quicker to changes in the accelerator pedal position. The system also switches "Servotronic" or "Active steering" option to a more sports-oriented characteristic. Steering and holding forces on the steering wheel are given more sporty settings."
But don't get discouraged - FDC is available on all E60. Here is the proof. You are looking at '07 E60 530i manual shift. Shorting FDC contact to the ground for a split second activates more crisp throttle response, steering becomes heavier in a good sense, and I'm sure on automatics trans shift points higher at any gear. And you get SPORT in the instrument cluster!
To disable FDC mode short contacts again.
Everything you need to get it done is in attached files, both pre-LCI and LCI E60s.
Home work: part numbers for Sport button and trim pieces.
Disclaimer: I'm not responsible for your speeding tickets! Nor for burned down control modules. Take it to a pro if you don't feel confortable tracing digrams or connecting wires.
Attached Thumbnails the way E60 was meant to be-e60-fdc1.jpg   the way E60 was meant to be-lci-fdc1.jpg   the way E60 was meant to be-prelci-fdc1.jpg   the way E60 was meant to be-prelci-fdc.jpg   the way E60 was meant to be-lci-fdc.jpg
Old 11-09-2012, 08:37 AM
BLooD's Avatar
Sounds too good to be true, The pre-LCI instrument (KOMBI) cluster has no sport symbol and for it to show on the LCI it would need coding which you do not state anyway.
Also you miss quoted Jeremy Clarkson. Take your rubbish else where please.
Old 11-09-2012, 08:46 AM
dbond's Avatar
With all due respect to your contributions to this forum you are wrong. Go and short pins 8 and 10 in SZM's X14056 then we will talk.
Old 11-09-2012, 09:21 AM
phlfly's Avatar
My Ride: 07' BMW 550i
So what is point of this you I can move my selector grear to DS (automatic tranny). Can you explain please?
Old 11-09-2012, 09:45 AM
Sanco's Avatar
More clarification on this please, any more pics of the install and possibly a more detailed DIY
Old 11-09-2012, 11:52 AM
lciaccio's Avatar
Originally Posted by sanco
more clarification on this please, any more pics of the install and possibly a more detailed diy
+1
Old 11-09-2012, 01:53 PM
BLooD's Avatar
Give me video proof instead of photo shopped pictures.
Old 11-09-2012, 04:26 PM
dbond's Avatar
Old 11-09-2012, 04:33 PM
phlfly's Avatar
Originally Posted by dbond
So again So what is point of this you I can move my selector grear to DS (automatic tranny). Can you explain please?
Old 11-09-2012, 05:13 PM
sanjsanj's Avatar
My Ride: E60 530d
i.e. what's the difference between this and using DS mode?
Quick Reply: the way E60 was meant to be
