Bluetooth Will Not Activate on Idrive Setting
Old 07-20-2011, 09:46 AM
FrankyNJ535xi's Avatar
Hi. I own a 2008 535xi and I recently deactivated my Bluetooth within my idrive settings due to my phone jamming up. When I go back into the idrive settings under bluetooth, it shows that it is deactivated and the box next to it is unchecked. When I press the mouse down to activate it, it doesn't turn on. Anyone have this problem before?
Old 07-20-2011, 10:50 AM
BestGear's Avatar
Strange though it may seem, I had the same thing, and it was the fuse!
No reason for it to go...and never did it again...
Worth checking as its only 2mins time.
David
Old 09-22-2011, 01:27 PM
pyramids111's Avatar
David
Hi,
What is the fuse for the bluetooth that you changed? I am having the EXACT same problem on my 2004 530i. I looked at the fuse map in the tool kit area, and could not find anything for the bluetooth.
Thank you so much!
Old 10-03-2011, 02:44 AM
cookceramics's Avatar
There is no fuse for the bluetooth that I know of. Your ulf module has most likley died. Just happened to me and I have the same problem. My audio also cuts in and out. Good luck!
Old 01-22-2012, 04:44 PM
camshaft's Avatar
I am having this exact same problem on my 04 545i. I bought this car last August and it has the dension gateway 500 installed for ipod integration. Could this be why my bluetooth won't activate? I have never been able to get the bluetooth to activate since I owned it.
Took it to the stealer the other day. Some dude came and looked at it and gave me no advice. Said it probably is because I have the dension...but they would be willing to look at it for $100.
I love to hear more about this fuse?
Old 03-07-2012, 12:25 PM
So what did you end up doing? Mine has the same exact problem. the bluetooth and audio.... please let me know asap.
i woudl apprecieate an email from you at sohaib (dot) bari (at) gmail (dot)com
thank you so much
Old 03-07-2012, 12:26 PM
hi... what did you end up doing? did that problem get fixed??
please lemme know asap. would appreceiate and email at sohaib(dot)bari(at)gmail(dot)com
thank you!!!
Old 03-13-2012, 12:46 AM
1Animal1's Avatar
My Ride: 535D Tourer - Pre LCI
This is bizarre - I have just wired in a dension (although dont have it working yet) and all of a sudden the bluetooth is coming up with a paragraph message saying to activate it in the car.... yet my phone pairs up to it but doesnt utilise? also the radio keeps cutting in and out too....
Old 03-13-2012, 04:31 AM
by the way... my audio cuts in and out too. for like the first 5 mins of starting the car. then its fine.....
and blutooth still doesnt work!!
Old 03-13-2012, 04:52 AM
1Animal1's Avatar
I've just taken a reading of my settings screen - says 'Bluetooth communication active. Please switch on bluetooth in the vehicle, to pair a new phone or to connect a phone previously paired to the vehicle'
Yet it won't let me tick the box :/
Quick Reply: Bluetooth Will Not Activate on Idrive Setting
