I think it's a vacuum leak - help me confirm
Old Feb 26, 2018 | 01:36 PM
insightbrewery's Avatar
My Ride: M3
Model Year: 1998
Default I think it's a vacuum leak - help me confirm
Hey guys, I just finished a valve stem seal job on a friend's 2008 550i. Now, the car is running rough at idle and idles high (750 RPM). It's throwing codes for the EVAP solenoid, vanos intake and exhaust on bank 2, and cps intake and exhaust on bank 2. No lean codes.
Long-term fuel trims are at 2.3 and 0 for bank 1 and 2, short-term pegs at 25 for both banks. Goes down to 0 if I rev quickly, which makes me think it's a vacuum leak. MAF reads 6.5 g/s at idle, which I believe is normal.
I'm guessing I cracked the valve cover when installing it, what do you guys think?
Old Mar 1, 2018 | 03:45 PM
Gee_115's Avatar
My Ride: 07 550i Sports Package
If its a vacuum leak it will idle rough on cold start then normal once the car is at regular temp. Also, listen for a whistling sound if its a vacuum leak.
Alexe60crock
Feb 29, 2016 04:53 PM
Rummat81
DIY: Do It Yourself
Mar 5, 2014 12:20 PM
545MMM
May 15, 2013 02:21 AM
vlad_b
Apr 2, 2012 01:09 PM
turboawd
Oct 20, 2009 06:46 PM
