Lidatek Laser Echo LE-30 (Laser Diffuser)
LE-30 System: includes one laser transponder, interface box, alarm speaker, alarm LED, system switch, bubble level, instructions, harness, mounting hardware.
- Brand new in box
- $200 (+ shipping)
The Lidatek LE30 is probably the world's best performing laser diffuser. It actually stops the laser from recording your speed for 5 seconds and gives you a visual and audio alert inside the car so you have time to check your speed and, if necessary, safely reduce your speed to the posted limit.
The LE 30 detects the laser beam from the police speed trap and then fires back a laser signal on the same frequency which prevents the laser gun's computer from computing the speed reading.
WHAT'S GOOD ABOUT IT?
It uses the same type of Laser diode that is actually used in police laser guns. Other diffusers often just use a lower cost diodes that can still do the job but take more energy to do so and can suffer power fade over time.
A single transponder is enough to provide protection for most cars, making the installation much easier. You can add up to two extra transponder units easily if you need to. Therefore you can mount one on the rear of your car to protect you from being targeted from behind, or an extra one on the front if you are driving a larger vehicle or just desire the highest level of protection.
On larger vehicles like pickups and SUVs, it's best to use two transponders for maximum protection against police laser. You should also use two transponders if your car has a lot of chrome on the front. The vast majority of the time, police laser is shot at approaching vehicles. Front targeting gives the officer more time to pick out the vehicle. Targeting from the rear is uncommon.
- Brand new in box
- $200 (+ shipping)
Aartsy19
08-08-2015 08:33 AM
