Car and Driver tested 330i - FAST,530i should too
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
I just got April's Car and Driver magazine. They tested a 6 speed 330i and it ran 0-60mph in 5.6 seconds. Quarter mile in 14.3 @98mph.
The 330i has the same gearing and final drive ratio as the 530i. So, weight should really be the only difference in the performance between these two. Are we looking at a sub-6 second car with the 06 530i?
Other interesting info: I saw in Road and Track that BMW estimates the 330i will get to 60mph in 6.3 seconds. The estimate I saw for the 06 530i is 6.4 seconds (I can't remember who published this, I want to say I saw it on a BMW site).
The curb weight listed for the 06 330i by C&D is 3450lbs. The weight listed for an '04 530i is 3756lbs.
Does anyone know how much lighter the 06 530i is supposed to be? This car should be faaaast.
The 530 with the R6 engine should have some pep, but I doubt it will be a sub 6 second car from 0-60. The current 545 has been timed at 5.7 from 0-60 so I just don't see it.
Manual Transmission
Premium Audio
Rear sunshade
Sirius Radio
Originally Posted by heezy545i' date='Mar 9 2005, 09:17 PM
The 530 with the R6 engine should have some pep, but I doubt it will be a sub 6 second car from 0-60.? The current 545 has been timed at 5.7 from 0-60 so I just don't see it.
[snapback]99361[/snapback]
Car and Driver tested the 545i at 5.4. So I do see it. They always have great times though.
The street start (5-60) on the '06 330i is 6.0. That's nearly a half second faster than the 03 330i. Says a lot about the R6 engine. You have a point about the 5-60 being closer to reality since most of the time, we're not going to be hammering the car the way a magazine tester would. With that said, 0-60 is still a valid metric to compare a car's performance relative to other models and a measurement of absolute performance even if one must disrespect the car to achieve it.
Originally Posted by UUronL' date='Mar 9 2005, 06:36 PM
[quote name='heezy545i' date='Mar 9 2005, 09:17 PM']The 530 with the R6 engine should have some pep, but I doubt it will be a sub 6 second car from 0-60.? The current 545 has been timed at 5.7 from 0-60 so I just don't see it.
[snapback]99369[/snapback]
[/quote]Their test track is donwhill
Manual Transmission
Premium Audio
Rear sunshade
Sirius Radio
Originally Posted by EBMCS03' date='Mar 9 2005, 09:42 PM
[quote name='UUronL' date='Mar 9 2005, 06:36 PM'][quote name='heezy545i' date='Mar 9 2005, 09:17 PM']The 530 with the R6 engine should have some pep, but I doubt it will be a sub 6 second car from 0-60.? The current 545 has been timed at 5.7 from 0-60 so I just don't see it.
[snapback]99370[/snapback]
[/quote]Quoted from Car and Driver regarding its test methodology:
"Acceleration - Elapsed times from 0 to 60 mph and through a quarter mile distance using full-throttle acceleration. Test vehicle is loaded with driver, full tank of fuel, and 10 pounds of test instrumentation. With manual transmission cars, wheelspin or clutch slip or both are used at the starting line to make best use of the engine's power characteristics and the vehicle's traction. All upshifts are lift-throttle with the clutch disengaged. With all transmissions, various shift points are tried to maximize performance. The redline is never exceeded. Time, speed, and distance are measured using a Racelogic VBOX GPS-based velocity sensor. All performance results are corrected to standard atmospheric conditions."
I've been reading this magazine since I was a kid, their science is generally pretty solid.
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by EBMCS03' date='Mar 10 2005, 03:42 AM
Their test track is donwhill? ? ?
Motor trend tested a 545i step at 5.3 from 0-60, but I've yet to see another mag equal or better this time. Haven't been up on the articles, but I've seen manuals and SMGs in the 545 form get poorer times. So go figure.
Either way, I should be in a 330i by end of fall
(not trading in my car though)
Manual Transmission
Premium Audio
Rear sunshade
Sirius Radio
Originally Posted by heezy545i' date='Mar 9 2005, 09:57 PM
Motor trend tested a 545i step at 5.3 from 0-60, but I've yet to see another mag equal or better this time.? Haven't been up on the articles, but I've seen manuals and SMGs in the 545 form get poorer times.? So go figure.
Either way, I should be in a 330i by end of fall ?
[snapback]99379[/snapback]
I'm starting to see a trend. This will either turn into a 3 series vs. 5 series or a 545i vs. '06 530i discussion, but that's not my intention. I'm simply excited about my planned purchase - should be placing an order this weekend for an '06 530i. Regardless of the actual tested times, it will be plenty quick for me.
The 545i automatic's final drive ratio is 3.38:1, which should provide better acceleration in every gear compared to the manual's final drive ratio. If the step shifts quickly enough, it could easily best both manuals. Same would be true for the 530i, but the gearing provides even more of an advantage to the step.
