Accelerate Rapidly for Better Gas Mileage
#21
Originally Posted by Bimmer32' post='227638' date='Jan 21 2006, 08:12 PM
Are you saying to start the car in 4k-5k rpm is the most efficient way? It appears that when I drive 48 mph (per the mpg rating), my rpm is at around 2k range. Wouldn't that be the most efficient rpm range?
#22
Originally Posted by Bimmer32' post='227655' date='Jan 21 2006, 10:31 PM
If I accelerate to 4-5k rpm every time to cruising speed, I'm going to hit every cars that's in front of me.
#23
The torque is abysmal in the low rpm range (on my 530) so I think that getting the car moving requres more rpm and thus, as mentioned before, it is more efficient to rev higher in lower gear at the start.
I didn't see anyone put it this way, so I will... you want to run the engine at the lowest rpm as much of the time as possible to save gas, so accelerate spritely to get through the gears into overdrive as soon possible so on average, the rpms are low.
Of course, never stopping helps too.
#25
Originally Posted by Trev550i' post='227534' date='Jan 21 2006, 03:27 PM
so you always drive in ds mode znod and accelerate fairly quickly? Do you have to replace the brakes more often?
#26
[/quote]
Wearing my glasses willl only add weight to my car. But I get the idea. As for the beer can test, I have to admit that you're a good adaptive driver - able to quickly adapt to active steering.
#27
[/quote]
Me too. Maybe we should compare CBS numbers on the brakes. I use a lot of DS/manual mode. My current mileage is 16,500 miles and my CBS says another 43,000 miles for both front and rear brakes. It steadily built up to that number and seems to have held there for several 1000s of miles. That would put my at replacing brakes at near 60,000 miles. I better start using them more so I can get a free replacement prior to 50,000 warranty miles
#28
