BMW X5 engine oil + oil filter change . Engine N63
How to replace your engine oil and oil filter, on BMW X5 50i. Engine oil and filter replacement, using Total Ineo C3 5W40 engine oil. How to install oil filter and which tools you will need for the bmw X5 N63B44 Oil replacement.Changing the oil on your BMW X5 50i E70 doesn’t have to be an expensive service as BMW likes you to believe. Once you purchase the right tools, it should only take about 15 to 20 minutes and your car is services! I purchased the oil and filter from my local TOTAL dealer which came out to about $50-60 which is less than one third of the cost of changing oil at the BMW dealership. I also show how to reset the oil service light.
See 😉 below 👇. |
| All times are GMT -8. The time now is 03:42 AM. |
