30FF error
Old May 20, 2020 | 10:21 AM
Candoman's Avatar
My Ride: 2008 535xi, stock
Default 30FF error
I was directed to this forum from another Bimmer owner. I have a 2008 535XI that is throwing a Engine Malfunction reduced power error. I took it into the shop and they found a vacuum hose that was disconnected and reconnected it. They mentioned that the error thrown was 30FF and have me monitoring until the error becomes more prevalent before they will do anything. Is there something that I can do in the meantime to fix this my self. With directions I can do most things.
Operational but concerned in Seattle
Old May 20, 2020 | 01:27 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
That code is for a vacuum hose disconnected or open. If they put it back the code should be gone if it's still there they didn't fix it and you still have an issue with open vacuum on one of your lines.
If you still have the code then check your lines and change the one that is bad. Ensure the nipples/canisters they are attached do not have a crack in them. That's all we can advise you to do.
Old May 20, 2020 | 01:37 PM
Candoman's Avatar
Thank you I will look into that.
Albnton1970
Jun 28, 2016 11:24 AM
wellison
Jan 20, 2016 06:59 AM
username83
Aug 4, 2013 11:12 PM
nyceric03
DIY: Do It Yourself
Dec 15, 2011 10:42 AM
monsterj34
Feb 25, 2009 06:12 PM
