Glad to have joined in the fun HELP!
HELP!!!
Bought the car in MAY, 525d on a 55 plate and its loads a stoopid faults. 1 Airbag lights on 2 Passenger seat bongs so have to have the belt plugged in all the time 3 I drive not working properly Satnav doesn't work DVD doesn't work Radio rec isn't great 4 fault "Key not in ignition car maynot restart" . So now I can lock the car and open the boot but can't open the car. Sometimes it will open and sometimes it will start but most of the time nothing comes on when I turn the ignition on. I don't have a rechargeable battery diamond key I've the 1 pictured below. THE previous owner had an auxiliary plug fitted and cables to the boot for a sub box also change the Angel Eyes from standard to Blue. Could it all be connected? Or has anybody had similar problems? Any help appreciated 👍🙏🙂https://cimg4.ibsrv.net/gimg/5series...412e71228c.jpg https://cimg2.ibsrv.net/gimg/5series...3a33118bad.png |
Did you know all this when you bought the car? :huh:
Originally Posted by Si525d
(Post 1601238)
HELP!!!
Bought the car in MAY, 525d on a 55 plate and its loads a stoopid faults. 1 Airbag lights on 2 Passenger seat bongs so have to have the belt plugged in all the time 3 I drive not working properly Satnav doesn't work DVD doesn't work Radio rec isn't great 4 fault "Key not in ignition car maynot restart" . So now I can lock the car and open the boot but can't open the car. Sometimes it will open and sometimes it will start but most of the time nothing comes on when I turn the ignition on. I don't have a rechargeable battery diamond key I've the 1 pictured below. THE previous owner had an auxiliary plug fitted and cables to the boot for a sub box also change the Angel Eyes from standard to Blue. Could it all be connected? Or has anybody had similar problems? Any help appreciated 👍🙏🙂https://cimg4.ibsrv.net/gimg/5series...412e71228c.jpg https://cimg2.ibsrv.net/gimg/5series...3a33118bad.png the radio reception on my e60 is crap too, probably needs a new aerial, but as I don’t tend to listen to the radio doesn’t really bother me auxiliaries plug unlikely to cause the issues, the replacement lights may cause canbus issues but that likely showing as blown bulbs hope some of this resolved some of your issues 👍👍 |
| All times are GMT -8. The time now is 05:17 AM. |
