worlds biggest swimming pool
My Ride: Mini Cooper
http://hk.youtube.com/watch?v=g-OBQ5iwEIw
http://www.sanalfonso.cl/ingles/main.html
If you like doing laps in the swimming pool, you might want to stock up on the energy drinks before diving in to this one.
It is more than 1,000 yards long, covers 20 acres, had a 115ft deep end and holds 66 million gallons of water.
Guinness Book of Records named the vast pool beside the sea in Chile as the biggest in the world.
But if you fancy splashing out on one of your own - and you have the space to accommodate it - then beware: This one took five years to build, cost nearly 1billion and the annual maintenance bill will be 2million.
The man-made saltwater lagoon has been attracting huge crowds to the San Alfonso del Mar resort at Algarrobo,! on Chi le's southern coast.
Its turquoise waters are so crystal clear that you can see the bottom even in the deep end.
It dwarfs the world's second biggest pool, the Orthlieb - nicknamed the Big Splash - in Morocco, which is a mere 150 yards long and 100 yards wide. An Olympicsize pool measures some 50 yards by 25 yards.
Chile's monster pool uses a computer- controlled suction and filtration system to keep fresh seawater in permanent circulation, drawing it in from the ocean at one end and pumping it out at the other.
The sun warms the water to 26c, nine degrees warmer than the adjoining sea.
Chilean biochemist Fernando Fischmann, whose Crystal Lagoons Corporation designed the pool, said advanced engineering meant his company could build "an impressive artificial paradise" even in inhospitable areas.
"As long as we have access to unlimited seawater, we can make it work, and it causes no damage to the ocean."
![worlds biggest swimming pool-_cid_04dc83b9a98347d8a3a4b96d1c462930_pc61liam.jpg](https://5series.net/forums/attachments/lounge-5/67782d1482365736t-worlds-biggest-swimming-pool-_cid_04dc83b9a98347d8a3a4b96d1c462930_pc61liam.jpg)
![worlds biggest swimming pool-_cid_8bbdb39eae8f47a5a1347553b94afb6d_pc61liam.jpg](https://5series.net/forums/attachments/lounge-5/67783d1482365736t-worlds-biggest-swimming-pool-_cid_8bbdb39eae8f47a5a1347553b94afb6d_pc61liam.jpg)
![worlds biggest swimming pool-_cid_18b850eea09a4b5480ca19651a80af9f_pc61liam.jpg](https://5series.net/forums/attachments/lounge-5/67784d1482365736t-worlds-biggest-swimming-pool-_cid_18b850eea09a4b5480ca19651a80af9f_pc61liam.jpg)
![worlds biggest swimming pool-_cid_914f417f029143b9bf449a1cd1db900b_pc61liam.jpg](https://5series.net/forums/attachments/lounge-5/67785d1482365736t-worlds-biggest-swimming-pool-_cid_914f417f029143b9bf449a1cd1db900b_pc61liam.jpg)
![worlds biggest swimming pool-_cid_f852d3d10a144e9e93e77f30f337efa4_pc61liam.jpg](https://5series.net/forums/attachments/lounge-5/67786d1482365736t-worlds-biggest-swimming-pool-_cid_f852d3d10a144e9e93e77f30f337efa4_pc61liam.jpg)
![worlds biggest swimming pool-_cid_d56868ca808b4d0094fb8f9474f822a2_pc61liam.jpg](https://5series.net/forums/attachments/lounge-5/67787d1482365736t-worlds-biggest-swimming-pool-_cid_d56868ca808b4d0094fb8f9474f822a2_pc61liam.jpg)
i just wanna see the pool guy and his bill for that maintenance
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
That's awesome. I would want to visit that place one day.
i wonder if someone will do laps on this pool maybe Phelps does
