True Tool Definitions
a. DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that freshly
painted part you were drying. But, if you are a bit slow, it will whack you
on the knuckles so hard you'll have no grip for days.
b. WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprint whorls
and hard-earned guitar calluses in about the time it takes you to say,
"Ouch...."
c. ELECTRIC HAND DRILL: Normally used for spinning steel pop rivets in their
holes until you die of old age
d. PLIERS: Used to round off bolt heads. OR, if you slip, making a blood blister
on your thumb or in your hand containing more blood than the blood mobile can extract.
e. HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable motion,
and the more you attempt to influence its course, the more dismal your
future becomes.
f. VISE-GRIPS: Used to round off bolt heads. If nothing else is available,
they can also be used to transfer intense welding heat to the palm of your
hand.
g. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your garage on fire. Also handy for igniting the grease inside a
brake drum you're trying to get the bearing race out of.
h. WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or 1/2
socket you've been searching for the last 15 minutes.
i. HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground after
you have installed your new front disk brake setup, trapping the jack handle
firmly under the front fender.
j. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a motorcycle upward
off a hydraulic jack.
k. TWEEZERS: A tool for removing wood splinters.
l. 'PHONE: Tool for calling your neighbor to see if he has another hydraulic
floor jack.
m. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-do off your boot.
n. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and
is ten times harder than any known drill bit.
o. TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
p. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
strength of ground straps and brake lines you may have forgotten to
disconnect.
q. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that
inexplicably has an accurately machined screwdriver tip on the end without
the handle.
r. BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid
from a car battery to the inside of your toolbox after determining that your
battery is dead as a doornail, just as you thought.
s. AVIATION METAL SNIPS: See hacksaw.
t. TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called drop
light, it is a good source of vitamin D, "the sunshine vitamin," which is
not otherwise found under motorcycles at night. Health benefits aside, it's
main purpose is to consume 40-watt light bulbs at about the same rate that
105-mm howitzer shells might be used during, say, the first few hours of the
Battle of the Bulge. More often dark than light, its name is somewhat
misleading.
u. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used, as
the name implies, to round off Phillips screw heads.
v. AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts
last tightened 40 years ago by someone in Sindelfingen, and rounds them off.
w. PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
x. HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
y. HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate expensive parts not far from the
object we are trying to hit.
z. MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well on
boxes containing seats and motorcycle jackets.
"Ouch...."
future becomes.
hand.
floor jack.
disconnect.
the handle.
misleading.
Banned
Very funny stuff!!
My Ride: 2004 BMW 530I steptronic, Orient Blue, Dakota Black Leather, Finishers Aluminium with Wave Cutting interior, NAVIgation, Radio PROFESSIONAL, CD in-dash, Hi-Fi extended sound system, PDC system, Bi-Xenons lights with washers, cruise-control, heated seats, Extended AC, auto"shade" mirrors, auto lights sensors, rain/wiper sensor, M-tech leather multifunction steering wheel, side airbags rearseats, sliding armrest, smoker's package (I don't smoke!), velour floor mats, spare wheel and jack, 122 style rims winter setup, M135 style rims summer setup
[color=red]Mods:[/color]
[color=blue]M tech sport steering wheel with M5 SMG paddles working retrofit done !
Trunk lid opening button retrofit done.[/color]
[color=blue]3M window 35% tint done
Chrome grilles
E60.net Clings
[/color]
Complete set of tools
