Tips on Pumping Gas
I have no idea on the validity of this. My friend just forwarded it to me and I thought it seemed fairly reasonable.
However, even if it's not...it might lessen the pain of always buying all that gas
...Serenity Now, serenity now......
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
I doubt if the temp of several thousand gallons in an underground tank is in phase with the outdoor ambient temp. I doubt if so much underground fuel changes enough to even measure.
Sounds like "old wives" advise to me.
And I do stomp on it now and then to eat up any such advantage.
![Doh](https://5series.net/forums/images/smilies/imported/doh.gif)
My Ride: E61 CarbonBlack 535d, Ventilated and Heated Comfort Seats with Massage in Black Nasca Leather, Dark Poplar Wood, Professional Navi, Folding Rear Seats, Load Through, Advanced Remote, PDC, Bluetooth, Dimming and folding Mirrors, Bi-Xenons, Hi-Fi, Tinted
Interesting info.. However 90% of the time I tank when having only last miles to go. I liked the dry ice trick though!! Will try
My Ride: E46 330, E60 550 on order: Carbon Black/Natural Brown, 6MT.
Originally Posted by UUronL' post='501159' date='Nov 30 2007, 02:07 PM
Aren't modern auto fuel systems pressurized to an extent? Once the cap is tightened properly, isn't evaporation largely nonexistent?
You can actually make the statement that a modern car produces less pollution running than a car from the 70's does parked with the engine off.
The part about the vapor recovery system is correct, except that only some states require vapor recovery systems, mostly in states with big air pollution problems. Large parts of the midwest do not have these systems.
As for ground temperature, it should not vary at all during the day. Around here, the ground temperature is around 50 degrees year round, once you get deeper than about 4 feet. That's the entire principle that makes geothermal heat pumps so efficient.
Sounds like CA emissions to me...
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
Yeah, I had been mulling this over... it occured to me that when I had kept a spreadsheet (more than a year with the E60), I certainly didn't see any significant variation in gas consumption that could be correlated to anything -but- tire pressure. I certainly didn't see anything that would suggest that temperature or seasonal variables were impacting mpg.
While I don't doubt that when you're talking about millions of gallons the environmental variables are critical, for the small amounts that the individual pumps, it would likely be unnoticeable. It should be easy enough to calculate though.
My own mileage calculations only suggested that tire inflation could seriously affect observed mileage. Keep them inflated if you want to see optimal results. The difference between "full" load pressures and partial loading was a good 2mpg.
Originally Posted by bad2bone' post='501127' date='Nov 30 2007, 10:02 AM
Yes! He means fill it up when it hits half full! ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
