Changing Brakes
My Ride: F10 535I
Model Year: 2016
I was planning on changing my brake pads today. i read all the DIY thread and am still confused I see that the Piston Needs to be pushed back. Is there anyway to push it back without all the specialty tools. would really appreciate any help as I 'm trying to get this done today or tomorrow and cant get an appointment with my shop/
Thanks
Thanks
First check the level of brake fluid in the master cylinder. Pushing the piston back might cause the level to rise and overflow. If necessary siphon off a couple of ounces.
Make certain the rubber bellows is clean and free of grit, spray it with silicone spray to preserve and protect. Try using a hardwood wedge to ease the piston back into the caliper. If it's difficult, with the caliper removed from the car, place the old brake pads into the caliper to protect caliper and piston and use a small prybar to push the piston back into the caliper.
Good luck ... may all your breaks (not brakes) be lucky ones!
My Ride: F10 535I
Model Year: 2016
Good luck ... may all your breaks (not brakes) be lucky ones!![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Thanks for the advise.
I used a "C" clamp and had no problems changed all in an hour and a half. Thanks again.
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
TexaZ3
05-06-2015 09:54 AM
