Tranny Fluid Change
Old 03-14-2009, 09:18 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
9) There were about 4 Liters and 100ml of tranny fluid drained out of the hole.
The color of the old fluid is about "tea brown" color.
10) The old drain plug was reused. It has the max. torque value on the plug - 8Nm. I used a little bit more than 7Nm to screw the plug back. I have a spare one ready just in case I overtightened it and break the plastic.
The fill plug is also hex. I tried 7mm, too small. Then I tried 10mm, too big !!! I am going to get 8mm and 9mm and then start to fill in fresh tranny fluid. That will be tomorrow morning - part 4.
Old 03-14-2009, 09:38 AM
MiamiPhill's Avatar
Nice write-up dude but you should have kept it all in 1 thread.
Old 03-14-2009, 09:57 AM
zerocool's Avatar
My Ride: 545i
+1
Old 03-14-2009, 10:41 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by zerocool' post='816628' date='Mar 14 2009, 01:57 PM
+1
I tried but forum did not allow me to post too many photos. That's why I broke it down 3 posts instead of 1 :-(
Old 03-14-2009, 10:57 AM
CWS530's Avatar
Thanks for documenting this. Nice work!
Old 03-14-2009, 10:58 AM
vesil's Avatar
My Ride: F11 520d
Waiting for part4!
What fluid you will use?
z06bigbird's Avatar
Besides, he have 2,000,000 posts in no time.
Old 03-14-2009, 11:05 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Originally Posted by vesil' post='816679' date='Mar 14 2009, 02:58 PM
Waiting for part4!
I am going to use the fluid from Pelican.com. Not cheap, but should be compatible with E60.
Old 03-14-2009, 01:57 PM
SmithsonGA's Avatar
surprised how the pan bolts have surface rust on them.
Old 03-14-2009, 05:48 PM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Waiting for part4!
The fluid can be purchased from either Pelican.com or RMEuropean.com. Pelican is a bit expensive than RMEuropean. So, I bought the fluid from RMEuropean. These are E60 compatible.
Quick Reply: Tranny Fluid Change
