Golf Tee Mod / Trunk Panel Help
Old Aug 30, 2009 | 06:27 PM
3Aims's Avatar
I was looking to pull the plug near the rear tail light but I can't get the left rear panel off in the trunk. I removed the only two screws I see but the panel still won't come off. Any ideas? 2010 535i.
Old Aug 30, 2009 | 07:55 PM
John@Motorcepts's Avatar
Banned
My Ride: A Car
Why do u want to pull the plug? where r u located? If ur in NY, I can help,
here's what u do. U already removed the two screws. Now, lift up the flap that covers the spare tire. Then wiggle the panel and it should come off.
Old Aug 30, 2009 | 07:59 PM
CWS530's Avatar
Golf tees?
Old Aug 30, 2009 | 08:11 PM
Gene's Avatar
Originally Posted by brabusw209amg' post='993506
Golf tees?
from e90posts
http://www.e90post.com/forums/showthread.p...ht=golf+tee+mod
Old Aug 30, 2009 | 08:18 PM
DRANGED's Avatar
Originally Posted by GENEaTALS' post='993518' date='Aug 30 2009, 11:11 PM
Hmmm, I thought the default for the valve on the e60 was closed and that the vacuum line served to open the valve. Not to mention the line is underneath the car on the exhaust, not behind the panel. Which begs the question..What is he doing with the golf tee?
FORE!!!!
Old Aug 30, 2009 | 08:21 PM
Gene's Avatar
Originally Posted by DRANGED' post='993526' date='Aug 30 2009, 09:18 PM
Hmmm, I thought the default for the valve on the e60 was closed and that the vacuum line served to open the valve. Not to mention the line is underneath the car on the exhaust, not behind the panel?
FORE!!!!
there are a few threads on e90posts debating on whether or not this mod does anything...
3Aims: I saw that you posted on n54tech.com...but you posted in the 5 series section...try posting that q in the FI section of both n54tech and e90posts...as those get more traffic...GL
before you say it DRANGED...no, I am not a forum slut
skeeter's Avatar
Originally Posted by GENEaTALS' post='993518' date='Aug 30 2009, 09:11 PM
Sorry Gene....Still don't get it....
Old Aug 30, 2009 | 08:27 PM
Gene's Avatar
https://5series.net/forums/index.php?showtopic=77979
the OP wants to keep that valve open the whole time...by doing this "golf tee" mod
some also think that if the valve is open the whole time there will be less back pressure build up thru the pipes...
Old Aug 30, 2009 | 08:33 PM
DRANGED's Avatar
I think the golf tee mod will do just the opposite on the E60, it will leave the valve closed all the time. On the 550 it is closed with the vacuum line disconnected. Perhaps it is different on the I6's?
Either way, leaving this valve open all the time will decrease low end HP. My understanding is that the valve serves two purposes. One is to quiet the exhaust at low RPM's, the other is to provide restriction to give more low end power. The valve opens at high RPM via the vacuum line to provide less restriction/higher flow rate and more high end HP.
FORE!!!
Old Aug 30, 2009 | 08:36 PM
skeeter's Avatar
Then why does he want to remove his rear panel in his trunk? The line runs in the trunk? I didn't know that....
