Sportautomatic (SAT) retrofit
Old May 16, 2008 | 02:40 AM
rsyed's Avatar
...some of you guys might have seen, but on day 1 I took my car apart and did the m5 retrofit. My car is now a week old and my confidence is sky high so I went to the dealer on wednesday and ordered the following parts that I picked up today
There are 3 stages to this exercise
Stage 1: retrofit just the SAT lever and the ECU with no SAT functionality
Stage 2: have the car coded for SAT functionality (Sports mode, faster shift times etc.)
Stage 3: paddle shifter retrofit
Stage 1 is due this weekend. I am 50/50 on whether stage 1 will work. My engineering background tells me, it should not work because the ECU has no firmware running on it so it will not work. Let us see - more to come later..
wish me luck
cu rumman
Old May 16, 2008 | 03:55 AM
xBMWx's Avatar
Is this the "kit" you PMed me about -- the one where a BMW dealer had retrofitted the SAT on a 535d? If so, hopefully they gave you good advice and instructions... GOOD LUCK!!
Old May 16, 2008 | 04:29 AM
rsyed's Avatar
this is not a retrofit kit, but I will make it one...
if all goes well, I will post DIY on the forum...
wish me luck
Old May 16, 2008 | 05:03 AM
jbsapphire's Avatar
This I think will be the first, awesome. Very best of luck. Keep us posted
Old May 16, 2008 | 05:23 AM
nicke60gre's Avatar
Is this compatible with Pre-LCI cars as well, or just only for LCI with standard Auto?
Old May 16, 2008 | 05:25 AM
rsyed's Avatar
no no, it is only for LCI cars with the standard "ugly" automatic shifter...
Old May 16, 2008 | 06:22 AM
nicke60gre's Avatar
Nice, good luck to you LCIers, seems doable
Old May 16, 2008 | 06:42 AM
Dandle's Avatar
My Ride: 07 E61 530d M-Sport.
Is the only difference with the sports automatic transmission the selector lever and ecu then? Seems it must be the only difference after looking at bmws site the sport auto is only another ?100 on the 535d.
Old May 16, 2008 | 06:45 AM
rsyed's Avatar
Yes, the difference is the ECU and selecter lever, and the Sports button
As said, stage 1 is to get this thing physically in. Stage 2 is to get the dealer to enable the SAT features on my car. And Stage 3 are the paddles...
cheers
Old May 16, 2008 | 06:47 AM
Dandle's Avatar
cheers
Thanks for that. Out of interest how much did the parts set you back?
