BMW EMBLEMS
Old May 11, 2009 | 05:42 PM
misal1091's Avatar
My Ride: '07 530i
hi i just bought bmw emblems for my steering wheel, trunk, and hood (from trinity sports), and i wanted to put them in myself
any specific procedures? thanks much
Old May 11, 2009 | 06:12 PM
mhs525's Avatar
The hood and trunk are press fits, you need to get something under them to gently pry them up. The trick is not scratching the paint. I surround the emblem with a couple layers of masking tape and used a small screw driver.
Old May 11, 2009 | 06:20 PM
we usually use a flathead wrapped in a microfiber towel for the roundels on hood and trunk. the one for the steering wheel sticks onto the original roundel, since the original roundel is part of the airbag. thanks again man
Old May 11, 2009 | 06:21 PM
BMWRINO's Avatar
Here's a random website with emblem removal instructions.. it's not specific for the E60, but it's the same idea.. good luck http://www.pelicanparts.com/bmw/techarticl...E30-Roundel.htm
Old May 11, 2009 | 07:08 PM
misal1091's Avatar
My Ride: '07 530i
thank you both! cant wait to install them tomorrow
Old May 11, 2009 | 07:27 PM
flyingpuck's Avatar
Nice DIY, thanks!
Old May 11, 2009 | 08:54 PM
tex_phil's Avatar
My Ride: 04 525i, 04 Dinan M3
Be very careful, I used a credit card and the entire circle around it is all scratched, and when I was attempting to use a tool to remove it with a towel around it, it slipped and caused a large sratch.
Old May 12, 2009 | 01:27 AM
Jrowe's Avatar
My Ride: 2005 545i Sport Package Limo Tinted, Heads up display, Fully Loaded Minus Cold Weather Package and Rear window Sunshades.
Dang, Really? I thought it came off? Mine has a big dent in it. I was looking forward to popping that thing off and replacing it with something cool... Are you positive about this?
Old May 12, 2009 | 01:32 AM
selbycy's Avatar
Im going to try the fishing line method when my CF ones arrive hopefully later this week or next week
Old May 12, 2009 | 08:23 AM
stoic1's Avatar
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
I had to replace the hood emblem a month or two ago. I used a plastic tool with a blunt edge from a computer tool kit to gently lift the edge of the emblem and had so scratching of the paint. I then used 4 inner threads about 18 to 24 inches long from some parachute cord I had laying around, I placed two of these threads over the top edge to the emblem and the other two on the bottom edge and had them meet in the middle. I gathered up the threads and then pulled firmly, that puppy came off straight away.
Once the old emblem was removed I cleaned out any dirt and debris that had gathered beneath it. For grins I put two coats of wax on the emblem area. I replaced the two rubber grommets, then firmly pressed in the new emblem and that was it. Job done.
