5Series.net - Forums
-   G30 Discussion (https://5series.net/forums/g30-discussion-58/)
-   -   2018 G30 Sedan (https://5series.net/forums/g30-discussion-58/2018-g30-sedan-153537/)
Bejiita78 Oct 22, 2023 11:22 AM
2018 G30 Sedan
Hello,
I recently got a "Reverse Light Malfunction" message in the idrive. I have replaced the affected tail light, driver side inner, but error still exists and tail light does not come on. Brake light and turn signal does work. I know there are three fuse boxes in the car, but unsure about which one holds the fuse responsible. I also haven't ruled out there's a module that is borked for some reason. Anyone else run into similar issue?
seanjordan20 Oct 22, 2023 11:26 AM
I would look at the actual assembly and plug first. Something made it go bad and I would assume a water issue
Bejiita78 Oct 22, 2023 02:18 PM
ok, I did replace the tail light assembly itself. I may have to dive back in there and look at the wiring/pins. Is that what you are saying?
donpb Oct 22, 2023 02:48 PM
Yes.
donpb Oct 22, 2023 03:13 PM
I would swap the bulb with the other side. If the problem does not follow, I would swap the entire assemblies. Also, check the contacts for oxidation or burn marks.
