2008 528i back up light replacement
My Ride: BMW 528i
No access to back up bulb. Must remove the truck liner. First 2 plastic screws to remove. Once I've done that I cannot remove the truck liner to access the bulb. Is there a secret to pulling the liner away to reveal the bulb assembly?
My Ride: 2007 52i5 Cold Weather, Premium Package, A6 ----2007 335i Sport Pacage, A6
No secret, just pull it out remove the screws and carefully remove the side panel you will see the reverse light, just pull it out and replace.
