F11 535d Eisenmann 4 x 90 Tip Exhaust
I am considering replacing the OEM exhaust with the Eisenmann 4 x 90 mm setup but on reviewing the parts 'breakdown' diagram for the 535D it seemed to show a make up clamp just forward of each back silencer box which also concurs to the Eisenmann 'breakdown' parts diagram and description.
A check of the exhaust on the car does not seem to have the coupling clamp and is one piece can anyone advise! Ian |
You just need to cut it. This is a common procedure when installing aftermarket exhausts.
- Antti - |
Anyone recommend someone for fitting exhaust and alterations to valance..located in Merseyside
