Well I am thinking about using my E60's winter setup on my F10 550i xDrive when it arrives (plus a mobility kit). The tire sizes fit (245/45/18). But will the 123s fit the F10??
Fairly certain they are different offsets. I'll check on it for you...
Looked up on realoem.com - no go. Your 123s are ET20, the F10 wheels are ~ET33. They will most likely rub badly, because the 123s will stick out about half an inch more than the stockers. Might end up working okay, but it's a small chance. I'd say, you can try it - if it rubs, you know what to do :thumbsup: |
Originally Posted by v_therussian
(Post 1402183)
I have Style 118 (8x18 ET 14) 245/45 R18 rims/tires that were for a 650i (E63,64), and wanted to put them on my F11 for the winter. My F11 currently has the entry-level Style 236 (8x17 ET 30) with 225/55 R17.
The offset difference is +16 which means they stick out 16mm more than the current tires I have and are also 20mm wider. I went to the garage and the mechanics put them on. At the back they do not stick out, but at the front they do a little (the tread not the rim), which would mean they would fail an inspection here (every 4 years). They do not touch or rub anywhere even at full lock. Though the garage said they are absolutely fine, they did not test at speed (yet), and to be clear I am still mulling over whether to put them on or not. Just my 2-cents worth. |
(Post 1402183)
Looked up on realoem.com - no go. Your 123s are ET20, the F10 wheels are ~ET33. The 19" and 20" F10 OEM wheels are F 8,5x19" or 20" ET's33 and R 9,0x19" or 20" ET's44. The 19" tires are F 245/40 and R 275/35 and for the 20" wheels F 245/35 and R 275/30. So there's pretty much room for the tires. The set that sdg1871 has just might fit, go for a try before you sell the winters. PS. The xDrive may have different ET's, I don't know. |
Originally Posted by Ricracing
(Post 1402344)
Actually the OEM F10 18" wheels are F and R 8x18" ET30, tires 245/45.
The 19" and 20" F10 OEM wheels are F 8,5x19" or 20" ET's33 and R 9,0x19" or 20" ET's44. The 19" tires are F 245/40 and R 275/35 and for the 20" wheels F 245/35 and R 275/30. So there's pretty much room for the tires. The set that sdg1871 has just might fit, go for a try before you sell the winters. PS. The xDrive may have different ET's, I don't know. But "I ain't mad at ya, I got nutn but love by you" ;) |
(Post 1402471)
I don't know what you were trying to achieve with this post, since it says exactly what I had said earlier, but more vaguely :geek:
To get some disarray for you dear Russian, the Style 123 BMW OEM wheels are ET20, but for the E60x they are ET43... Check out the facts! |
(Post 1402648)
Well, how can I write more simple about the F10 OEM wheel ET's and tire sizes :confused:
Hi frederic73 and welcome to the Forum.
Well, this tells where the limit goes. Please bros, get wheels and tires with in the OEM standards, better and safer rides :twoup: |
Originally Posted by sdg1871
(Post 1402650)
I do not know if my 123s came off of an x or a non-x. Looks like I will need to try them on my F10 and see how things fit.
How many months do you use the winters? I will put on my winters on this friday and change them back for summers in early April, about four months. But the damned 18" winters are a must - I hate the winter. |
