F10 Parts, Accessories and Mods Discussion about both stock and aftermarket parts for the F10. Accessories and modifications too!
right led eyebrow is not working
Old 08-24-2011, 01:09 PM
My Ride: BMW 525 E60
Hello !
Recently I had a moisture in my right Led eyebrow and it worked just fine, but I had a stupid idea to get the moisture out by taking the headlight out and puting it in a warm place (near the radiator) I waited for about 4 days and nothing changed so I decided to put my headlight back. Now my headlights right eyebrow is not working proper, only 2 leadlights is now working on that right eyebrow and is not as bright as before. Left side is working just fine but the right side eyebrow is having problems.
So I would like to ask for a suggestions! What should I do? Is there any fuse I need to change? Is there any wire or any other method to fix this?
Thanks
gankstar23 is offline
Old 08-25-2011, 10:43 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
You already made a thread about this, right? And you still have an E60?
https://5series.net/forums/topic/115...1#entry1370393
Did you try an external power supply trick? If you did and it didn't help, I think the only way is to cut the LED section open and change the leds. There are some threads about that on the forums.
- Antti -
Anzafin is offline
Old 08-25-2011, 01:46 PM
- Antti -
Hi,
Thanks for that suggestion,but were can I get that external power supply and I'm not sure where to connect it, is it on that plug of that eyebrow or the actual eyebrow?
Old 08-30-2011, 02:43 AM
Anzafin's Avatar
You should connect it straight to the eyebrow.
Anzafin is offline
Old 08-31-2011, 10:44 AM
Ricracing's Avatar
Voi itku tota kaveria! Translation: Nice help my friend.
Ricracing is offline
Old 10-22-2011, 05:45 AM
Will it charge with only 12V, I just can't find power supply with 17V !? Maybe you could suggest witch power supply to use?
Thanks
Old 10-22-2011, 06:57 AM
Anzafin's Avatar
An exteranl power supply will not charge anything, but with a adjustable power supply you can give more volts for the eyebrow to make it light up.
With a 17V they surely will be lightened up, but I'm not sure would it be good idea to give them 17V for a long time.
I have a self made adjustable power supply.
- Antti -
Anzafin is offline
Old 10-22-2011, 10:03 AM
- Antti -
ow Ok! It makes sense now. I don't think I will have the skills to make my own adjustable power supply, I think I will have to buy one. Do I have to use some special wires because when you try to connect it to the eyebrow they are to deep in so its hard to get to them them.
Thanks for the suggestion mate. Im sure it will help
Old 10-22-2011, 10:31 AM
Anzafin's Avatar
To connect the power supply into the eyebrow, I cut the eyebrow power wire and put a simple computer power connector between the cut ends. Then I put the same kind of plug into my adjustable power supply too. Now I can change between the original power wire (from car) to my power supply, if needed. Like this:
- Antti -
Anzafin is offline
Old 10-22-2011, 12:30 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
I love this drawing.
nomis_nehc is offline
Quick Reply: right led eyebrow is not working
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
