F10 Parts, Accessories and Mods Discussion about both stock and aftermarket parts for the F10. Accessories and modifications too!
Addition bass or sub
Old 07-16-2011, 04:20 PM
tonyb635's Avatar
Has anyone added a sub to their car with the factory radio system? I'm considering doing this and one possibility I was looking at was a powered Bazooka tube. Something clean and not too big. I'm not looking to custom build a cabinet in the trunk, I just think the car is lacking a little bass...
tonyb635 is offline
Old 07-19-2011, 01:02 PM
Ricracing's Avatar
Do you have have the HiFi Pro in your F10?
Ricracing is offline
Old 08-04-2011, 04:35 AM
subterFUSE's Avatar
You will need a line-output-converter to take the speaker level output from the factory amplifier and convert to a line level signal. Then you'll need an aftermarket amplifier to run the subwoofer or bazooka tube. Personally, I would suggest a subwoofer over anything by Bazooka.
subterFUSE is offline
Old 08-08-2011, 12:32 AM
Why would you need a line level signal? Sorry, I hear so many different combos of doing this.... confusing it is,
neilparmar is offline
Old 08-08-2011, 12:35 AM
Old 08-09-2011, 09:06 AM
subterFUSE's Avatar
In order to add a subwoofer to the factory system, you must have a way to tap into the audio signal of the factory system.
The factory radio does not offer a preamp output, so the only option is to use the speaker level output from the factory amplifier.
To use that, you must have a device called a Line Output Converter. This device takes the speaker level output from the factory amp, and converts it to a preamp level output which you can then use with an aftermarket amplifier to drive a subwoofer.
Jiawei Zhao
10-21-2015 08:46 PM
abrookey
E60 M5 Discussion
09-22-2015 05:05 PM
ripley
DIY: Do It Yourself
09-19-2015 06:21 PM
Dom Paulauskas
08-13-2015 04:38 AM
Quick Reply: Addition bass or sub
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
