Yes same old question, but I cant understand it.
Hi,
So the question remains the same. What is a high/low offset wheels. Is a wheel high offset when its more deep that means less distance between the center of the rim and the rings hub ? or is it vice versa ? Again, a high offset wheel has an ET of 20 or 40 ? Thank You. |
http://en.wikipedia.org/wiki/Offset_(wheel)
Higher offset is typically meaning a higher positive number when referring to BMW wheels. A higher offset wheel will be "tucked" more into the car. Most people prefer the "flush" look where a wheel and tires' outer edge is flush to the fender. |
Not Quite understood...
Originally Posted by snj1013
(Post 1494171)
Higher offset is typically meaning a higher positive number when referring to BMW wheels. A higher offset wheel will be "tucked" more into the car. Most people prefer the "flush" look where a wheel and tires' outer edge is flush to the fender. Am I correct ? But when I asked somebody they told me that since this car is on low offset, application is difficult for my car, which exactly the same as the car in the link, a 2006 Civic. Thank You |
