5Series.net - Forums
-   F10 Discussion (https://5series.net/forums/f10-discussion-33/)
-   -   Where is the OIL TEMP sensor located on 2011 528i?? (https://5series.net/forums/f10-discussion-33/where-oil-temp-sensor-located-2011-528i-152148/)
Donaldj79 Dec 15, 2021 06:15 PM
Been battling with several codes on this car. I have changed the Coolant Temp sensor up front. Not sure where the Oil Temp sensor is located? I've seen some say under the intake manifold? A diagram or picture with an arrow would be a great help.
Car cuts off and goes into neutral. EVERY time that happens...Oil Temp needle fluctuates significantly. Also takes 15-20 mins (or more) of driving, before the needle moves to operating temp.
https://cimg0.ibsrv.net/gimg/5series...2b3ea55987.jpg
donpb Dec 16, 2021 05:04 PM
Go to, RealOEM.com - Select Your BMW Model, search for coolant temperature sensor.
