sway bar bushing
Wud worn sway bar bushes cause vibration in steering wheel at 80klm
That can do it, but my experience with similar issues leads me to believe its more of a tire balancing issue when it varies at high speeds. Usually if the bushings are worn the ride smooth out at speeds,you would hear more of a clickity clack noise when you turn the steering wheel. e.g leaving a parking space, etc.
| All times are GMT -8. The time now is 10:34 PM. |
